Originally Posted By: gathermewool
Originally Posted By: Srt20
Originally Posted By: Cedarshark
I own 30 chainsaws and buy/rebuild and sell them. Your question(OP) is easy to answer. Any 2 stroke motor can be burned up at ANY oil to fuel ratio if it becomes leaned out at the fuel to air ratio. The fuel to air ratio is controlled by the high and low jets in the carb. So if you cannot adjust the carb for the particular mix you are running, my suggestion is to use the mfg suggested ratio. I tune with a tach made for 2 strokes and modern saws will run between 12,000 -14,000 rpm at WOT.
Have you ever seen an engine that calls for 50:1 ratio burn down at a 32:1 ratio?? Just curious since its only 1.4oz more oil PER GALLON....
If it lean burns down at 32:1 I promise you it would also burn down at 50:1.
Also, if it has carbon build up(which is a crock too) at 32:1, it will have the same at 50:1.
It's better to compare the effective ratio of gas/oil, instead of thinking of it from the point of view that the gallon is some huge unit of volume. 1.4 oz. may not seem like much, compared to 1 gallon of gasoline; however, a change in ratio from 50:1 to 32:1 is HUGE. The comparison of 4.0 oz of oil (32:1) to 2.6 oz of oil (50:1) is also the same amount of HUGENESS (exactly, if you can believe it!)
From 32:1 to 50:1 is a 54% increase in the amount of oil added!
From 40:1 to 32:1 is a 25% increase in the amount of oil added.
Originally Posted By: Mike72
This rebuild came after 6 seasons of use, did not have an hour meter during this time. I felt that was long enough to do an internal inspection and see if the 50:1 ratio was causing any problems, it was not.
Maybe I'm old school but generally speaking if an engine is running as intended and not showing any symptoms of failure of any kind, a rebuild isn't necessary.
I own two 1970s Lawnboys and they're completely original and still running as intended. I opened them up to take a look, put them back together, did a compression test and they were at spec. Those are forty year old engines with who knows how many hours on them running very well.
Still don't understand the reason to rebuild it if there was no wear?
By the way is your name Thomas or are you just looking for information?
Thomas? Did you mean George?
Wait; never mind, that doesn't work lol
The question is still the same.....
Have you, or anyone else for that matter, EVER seen an engine that calls for 50:1 ratio have a lean burn down because it was run at 32:1 mix??
Again, if it burns down at 32:1, it would burn down at 50:1.
