4EAT Subaru
by HowAboutThis. 02/16/19 10:38 AM
delete
by beanoil. 02/16/19 10:37 AM
First oil change
by Bill_W. 02/16/19 10:18 AM
Mobil M1-110A
by Purpfox. 02/16/19 10:17 AM
Oil recommendation for 2018 titan 4x2
by Ttown. 02/16/19 10:10 AM
M1 filters?
by dogememe. 02/16/19 09:44 AM
Granatelli Indy 500 and STP :)
by shanneba. 02/16/19 08:01 AM
2010 Chevy Corvette, Castrol GTX Magnatec 5w30
by montero1. 02/16/19 07:22 AM
veloster wheels on my sonata
by JustinH. 02/16/19 07:05 AM
Beast chewing on garage door seal
by LeakySeals. 02/16/19 03:01 AM
Weird Residue in New Fram Ultra
by mphilleo. 02/16/19 01:40 AM
0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
krzyq, Huberthagans, 3dfever, Mahmoud, Happycamper
67248 Registered Users
102 registered members (97prizm, 2002 Maxima SE, Ag76, 53' Stude, Al, 4WD, 9 invisible), 2,184 guests, and 53 spiders.
Topics298,270
Posts4,988,433
Members67,248
Most Online2,474
Feb 10th, 2019
2017 Mustang Auto Trans ATF Change Interval #4797676
06/26/18 01:14 AM
06/26/18 01:14 AM
USA
Maddog1337 Offline OP
USA
Hello Oil Connoisseurs,
I have a 2017 Mustang 3.7L with the 6R80E automatic transmission. While it's no 5.0, this is my first new car and I have thoroughly enjoyed modding and overall just driving the [censored] out of it. Particularly doing 6K-7K pulls with the paddle shifter manual mode to really accentuate my aftermarket exhaust. Now I know as an end result my driving behavior is likely causing my ATF to boil.
I was planning on changing at 30K mi, but now I'm starting to think perhaps even earlier? I have 10K mi on the car, and per my service manual I should be changing the ATF and filter at 150K mi. I simply cannot believe this to be true. Ford doesn't make it easy, there is no drain bolt or dipstick, and I would have to drop the pan. With only a condo garage at my disposal I'd probably have to take it to be serviced somewhere. Question being, should I be changing fluid ASAP or am I being a bit overzealous?
Thanks in advance
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797687
06/26/18 03:56 AM
06/26/18 03:56 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Driving the vehicle like you stole it, perhaps then changing the ATF at 10K miles isn't being overzealous. Although I don't think it will hurt the tranny, I do believe in keeping the factory ATF in there for longer(maybe 30K miles) so that the tranny breaks-in properly. Others will chime in with more info.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797689
06/26/18 04:12 AM
06/26/18 04:12 AM
NY
demarpaint Offline
demarpaint  Offline
NY
From what I've been told and read here and other places most of the wear in a new automatic transmission occurs in about the first 10k miles or so. So in your case I would change the fluid and filter early, like right about now. I would do a line off fluid exchange as well. Going forward if you're driving the car hard and "boiling" the ATF as you think you might be, I'd probably be servicing the transmission every 20-25K miles. Which might be overkill to some. You could pull a sample in about 20K miles after this fluid change and going forward base your service interval on that.
God Bless Our Troops
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797733
06/26/18 06:30 AM
06/26/18 06:30 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
A true Bitoger would change his tranny fluid every time he changed his oil. wink
If you want the job done right......do it yourself.
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797738
06/26/18 06:34 AM
06/26/18 06:34 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
It's the same trans that is in the F150 so it can take some abuse. Your not really harming the transmission by doing those 6-7k pulls. There's so much torque management in it that trans that you're fine. In the F150 mine doesn't heat up much until I start towing heavy and then it settles in at around 200-205. Put hills in there and the most i've seen it get to was 225. And that was foot almost to the floor holding 70 (speed limit and yes my tires are rated for 75) on the highway with 9k lbs behind it.
IIRC I think you can view trans temp in the gauge cluster in the 17's - it's a menu somewhere. I know the 18's have it and one of the parameters is trans temp. May be worth a look for your own sanity.
That being said I still think 30k changes are where you want to be. You can DIY by dropping the pan and unless they changed it, the dipstick is integrated into the fill hole on the passenger side. Unbolt the nut and the stick is in there.
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797789
06/26/18 07:50 AM
06/26/18 07:50 AM
socal
barkingspider Offline
socal
30k tranny OCI is more than plenty good.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Char Baby] #4797809
06/26/18 08:17 AM
06/26/18 08:17 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Break in happens if you change the oil hourly.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797810
06/26/18 08:22 AM
06/26/18 08:22 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
A new transmission breaking in puts the most crud in the oil. It will not hurt to change the oil and filter then get on a oil change schedule that makes you feel happy. I do an early oil and filter change then 30,000 mile drain and fill. " I vacuum out the oil then 60,000 mile filter change. It is probably overkill though.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797818
06/26/18 08:26 AM
06/26/18 08:26 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797848
06/26/18 09:17 AM
06/26/18 09:17 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
You are in no way taxing that transmission with a 3.7l in a mustang. That transmission has been around in the F150 since 2009 and is quite stout. I will never tell anyone not to change the fluid early ( I dropped the pan and changed the filter at 10k miles on my 2016 f150), but after that leave it for 50k miles without issue.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4797870
06/26/18 09:34 AM
06/26/18 09:34 AM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
30k should be good. Even 60k would be fine. Most cars never have their transmission fluid changed and end up at the junkyard on their factory fill.
Since you don't have a drain plug, buy an aftermarket pan that has one. It will make future ATF changes much easier smile
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: demarpaint] #4798003
06/26/18 12:26 PM
06/26/18 12:26 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
This, exactly. After the first change you can go 25-30k.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - daily driver
'00 Grand Marquis GS - bad frame/future to be determined
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: demarpaint] #4798155
06/26/18 03:30 PM
06/26/18 03:30 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
You want to flush the trans on a brand new car? Do you really think that is necessary? Even a pan drop and filter change at 10k I would argue is fairly zealous maintenance. If you were flushing it to put Redline or something it in then for sure.
You might be trading it in for a 5.0 within a year or two, so you should take that into consideration OP.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4798165
06/26/18 03:43 PM
06/26/18 03:43 PM
Downers Grove, IL
BBuzecky Offline
BBuzecky  Offline
Downers Grove, IL
Is this car all show no go? Post some pics always good to see Mustang owners make it their own. As for the ATF you aren't hurting anything by draining at 10k and replacing with quality Redline ATF.
Re: 2017 Mustang Auto Trans ATF Change Interval [Re: Maddog1337] #4798227
06/26/18 05:55 PM
06/26/18 05:55 PM
Northeastern Vermont
littleant Offline
littleant  Offline
Forget Ford's recommend 150,000 miles that's ridiculous. 30,000 sounds good.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Moderated by  ekpolk
