0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
37 registered members (alphadog, bfleeman, BlakeB, Blkstanger, anndel, 1WildPig, 1 invisible), 747 guests, and 56 spiders.
Topics298,255
Posts4,988,167
Members67,246
Most Online2,474
Feb 10th, 2019
Snapper LT3000 Hydro Tranny Overheated? #4797420
06/25/18 05:53 PM
06/25/18 05:53 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
Yesterday I was pulling my trailer with branches which probably weigh in around 500 lbs. I read that it can pull around 700 but I do have a hill and now wish I had not tried going up the hill. I could smell the oil and burning a little bit. I immediately dropped the trailer but did continue mowing. Mower was going up the hill slower than normal leading me to believe I may have damaged the transmission. I did change the fluid last year and put in Mobil 1 15W50. Would the fluid be destroyed and need changed or any thoughts to make it work right again.
Thanks
96 Grand Marquis
01 Sable LS
02 Montero
Re: Snapper LT3000 Hydro Tranny Overheated? [Re: spk2000] #4797437
06/25/18 06:11 PM
06/25/18 06:11 PM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
Maybe you smoked the drive belt?
If it's the trans, uh oh. Try it when the trans fluid is cold, if it degrades/slows after 10 to 20 minutes, then my guess is you fried the trans.
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: Snapper LT3000 Hydro Tranny Overheated? [Re: spk2000] #4797476
06/25/18 06:48 PM
06/25/18 06:48 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I think I would change the Transmission oil now and pray that all is well again. Ed
CX5 Touring 2.5L :-)
Re: Snapper LT3000 Hydro Tranny Overheated? [Re: spk2000] #4797522
06/25/18 07:33 PM
06/25/18 07:33 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Did the trans case feel hot? If not and the fins are clear and the fan works, I wouldn't worry about it. Just use it as intended.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Snapper LT3000 Hydro Tranny Overheated? [Re: spk2000] #4797751
06/26/18 06:51 AM
06/26/18 06:51 AM
WV
bchannell Offline
bchannell  Offline
WV
Even though the tranny "may" be rated for 700#, I'd say that's a bit of advertising liberty. I didn't look up which tranny is in it, but I'm sure it's not rated for a lot of uphill, heavy load use. That's certainly not to say it won't do some limited duty in that respect, but it sure isn't good to do it for long heavy sessions. In other words, that 700# rating is for short duration use and not constant use.
When you smell anything on your tractor getting hot, you should stop right there. Check the fans, oil, debris, etc. Then let it rest and cool down. Trannies can usually survive a bit of overheating, but not a bunch.
I agree with the above, change the oil now and hope. It's good news that it still moves, but when it got sluggish, that's when you're crossing the line into dangerous use. That's usually a very good signal to stop.
Hopefully, it survives to mow another day, good luck with it.
Re: Snapper LT3000 Hydro Tranny Overheated? [Re: spk2000] #4798181
06/26/18 04:24 PM
06/26/18 04:24 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
Thanks for the advice.
This mower has the Tuff Torq K57 transmission if this helps any.
Fluid was 10W30 but later upgraded to 15w50 so I used the mobil 1. Hoping it can take the heat.
Very difficult to suck it out with small vacuum line in top vent hole and even harder to gravity feed it back in through the same hole. Eventually I started blowing into hose to speed it up some. It's not really meant to be serviced I am pretty sure.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Snapper LT3000 Hydro Tranny Overheated? [Re: spk2000] #4810058
07/10/18 09:33 AM
07/10/18 09:33 AM
VA
Gebo Offline
Gebo  Offline
VA
Pray first grin And then check belt and change the fluid and make sure fluid level is full.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Moderated by  ekpolk
