decided flushing my trans fluid on my vic would be easiest done by disconnecting the bottom trans cooler line where it goes into the tranny cooler which is part of the ac condensor (more on that later)
well that all went fine, did a half gallon at a time using an empty clear jug of washer fluid.
but i'm an idiot and cross-threaded the fitting into the ac condensor. whoever thought that was a good idea isn't very smart because if it was part of the radiator, well, radiators are easy to replace.
to get home i chopped off the ends of the hard line and put in a hayden trans cooler. it sucked so this morning i used fuel line fittings to go back to the factory cooler/condenser unit.
problem is it leaks a bit. not much but just a tiny bit. i think i need a fatter o-ring where the end of the fitting pushes against the inside of the condensor.
anyway, just wondering what i should do to resolve this. i should have taken 5 mins extra to be patient and thread the thing nice in the first place instead of making this mistake and ruining an expensive and expensive to replace part like the ac condenser and tranny lines too. ugh
but here's all the tranny fluid i put through it...
