I have a 1998 Cherokee. It did not come with the tow package but I am installing a hitch. I won't tow more than about 2,000lbs with it. The manual says for towing you need a transmission cooler, which I'm installing also, and 85w140 gear oil in the rear. I've got some pretty fresh synthetic 90w in there, I'd really rather not change it. Plus towing will be very occasional, I don't want the thicker stuff in there when I'm not towing.
Is it that big of deal to try and tow with the 90w? I'd be at less than half the standard weight limit.
