"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
67 registered members (A1O, arowbat, aloe2018, AdditiveOCD, ARB1977, aircooled, 9 invisible), 1,366 guests, and 54 spiders.
Topics286,321
Posts4,906,384
Members67,599
Most Online2,967
Mar 10th, 2019
2009 Taurus strut mount noise #4796474
06/24/18 04:38 PM
06/24/18 04:38 PM
TN
terry274 Offline OP
terry274  Offline OP
TN
I have a 2009 Ford Taurus Limited FWD with 108,000 miles. This weekend I replaced the struts, springs and mounts with Monroe quickstruts.
Rockauto parts
The reason for the replacement was the old mounts made a clunking noise over bumps and potholes.
One of the new mounts seems to be stiff. That is, the spring makes a "boing" noise when I turn the wheel. It's not terrible but it was a lot of work for something to be "almost" right.
Is it possible the new mount will break in and allow the spring to rotate freely after a few miles? Or will it only get worse?
My option is to live with it or remove it and return it to Rockauto, which means I will be down a car for several days and have to go through the removal/installation hassle again.
Does anyone have any advise? Yeah, I know "get something other than Monroe". But they seem to have a lot of satisfied customers from the reviews.
Terry
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 2009 Taurus strut mount noise [Re: terry274] #4796495
06/24/18 05:16 PM
06/24/18 05:16 PM
ME
eljefino Offline
eljefino  Offline
ME
That's not okay and you need to fix it. Did you chuck the old parts already?
Re: 2009 Taurus strut mount noise [Re: terry274] #4796502
06/24/18 05:25 PM
06/24/18 05:25 PM
TN
terry274 Offline OP
terry274  Offline OP
TN
I still have the old parts. I am considering buying the mounts and keeping the old struts and springs if I have to redo it. The old struts still rode and handled great.
Terry
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 2009 Taurus strut mount noise [Re: terry274] #4796553
06/24/18 06:45 PM
06/24/18 06:45 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Well the springs usually settle after a couple weeks. But it's possible the mount is bad. I was chasing a noise for a while and didn't believe it could be the struts as I had changed them with Monroes about a year earlier. When I finally changed them a couple years later, the noise went away, I guess the mounts had worn out really quickly. There's no perfect strut though, some people like KYB, others hate them, same even with Moog. Sometimes it the luck of the draw whether you get a good set or not.
Re: 2009 Taurus strut mount noise [Re: terry274] #4796556
06/24/18 06:48 PM
06/24/18 06:48 PM
out there
spasm3 Offline
spasm3  Offline
out there
I would see how much oem mounts are, and swap mounts in the new quick struts. Also look and make sure the lower part of the spring is seated in the correct spot.
edit;
https://www.amazon.com/Motorcraft-AD1066...TORCRAFT+AD1066
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: 2009 Taurus strut mount noise [Re: terry274] #4796568
06/24/18 06:57 PM
06/24/18 06:57 PM
NY
mx5miata Offline
mx5miata  Offline
NY
checkout sensen shocks and struts
sensen
replaced my 98 F150 shocks with sensen truck handled mint and road wonderful.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: 2009 Taurus strut mount noise [Re: terry274] #4796646
06/24/18 08:34 PM
06/24/18 08:34 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I just installed the powerflex strut mounts that Trav reccommends and they are magnificent.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: 2009 Taurus strut mount noise [Re: terry274] #4796713
06/24/18 09:40 PM
06/24/18 09:40 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Total guess is you have something binding in the top mount. Back off on the bolts to the body and maybe a turn or 2 on the strut's top nut. Re-tighten after giving the mount a good shake to check stuff and to take out any bind from mis alignment. Back stuff off until you have only a full nut. Be careful to tighten the 3 (?) bolts evenly. don't forget top nut.
Thick oil is better grin2
Re: 2009 Taurus strut mount noise [Re: andyd] #4796739
06/24/18 10:19 PM
06/24/18 10:19 PM
CA
The Critic Offline
The Critic  Offline
CA
Agreed. Figure out why the assembly is binding. Remove the top mount and inspect. A lot of these quick struts use a different upper insulator and different spring seat design than the OE part.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: 2009 Taurus strut mount noise [Re: terry274] #4797131
06/25/18 12:13 PM
06/25/18 12:13 PM
TN
terry274 Offline OP
terry274  Offline OP
TN
An update. Thanks for the replies. I loosened the four bolts on the top of the strut mount and torqued them to the service manual specification.
No change.
The Monroe installation instructions say to torque the nut on the strut top rod after installation, however this is not possible on a 2009 Taurus with the unit installed.
I sent Monroe an email and am awaiting their reply.
Terry
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 2009 Taurus strut mount noise [Re: terry274] #4797234
06/25/18 02:17 PM
06/25/18 02:17 PM
VW Fanboy Island
VW Fanboy Island
You need special tools to torque them on my car, you have to hold the piston somehow and then use a 90 degree adapter to torque them. I usually just blast them with my impact lol, I have never had a problem but would like to know if there is an issue with this and how the pros do it.
Just tell them you torqued it. I have a feeling they might give you a hard time about that.
Re: 2009 Taurus strut mount noise [Re: terry274] #4797895
06/26/18 11:09 AM
06/26/18 11:09 AM
TN
terry274 Offline OP
terry274  Offline OP
TN
I called Monroe this morning. Kevin at Monroe said the he believed the strut mounts had been assembled incorrectly at the factory and he is sending me new strut mounts.
So, now I get to remove the struts again and compress the springs. Not having to compress the springs was the reason for the quickstrut. If I had been willing to compress the springs at the start I would have went with the Motorcraft parts.
On a positive note, the car rides and drives great with the Monroe struts.
Terry
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 2009 Taurus strut mount noise [Re: terry274] #4797916
06/26/18 11:32 AM
06/26/18 11:32 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What? No way! You bought a Quick-Strut, so if one is defective you get a new... Quick-Strut. Tell them you have no tools to disassemble the product you bought. Plus, what is the guarantee you will assemble it correctly? That responsibility is on them, not you.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: 2009 Taurus strut mount noise [Re: kschachn] #4797983
06/26/18 12:55 PM
06/26/18 12:55 PM
USA
slacktide_bitog Offline
USA
approved
Re: 2009 Taurus strut mount noise [Re: terry274] #4798344
06/26/18 09:20 PM
06/26/18 09:20 PM
out there
spasm3 Offline
spasm3  Offline
out there
Or go ahead and get some decent spring compressors and on any future strut jobs, you will same money and have a better assembly. I bought spring compressors 25 years ago, more than paid for themselves. Its not not hard or dangerous if you are mechanically inclined.
