Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
75 registered members (beanoil, aquariuscsm, 2strokeNorthstar, Best F100, 69Torino, 7 invisible), 856 guests, and 56 spiders.
Topics284,590
Posts4,873,006
Members67,294
Most Online2,548
Feb 16th, 2019
Filter for Hydro Gear ZT2800 - Toyota??? #4796248
06/24/18 11:39 AM
06/24/18 11:39 AM
NC
Lancruza Offline OP
Lancruza  Offline OP
NC
Hello, I just bought a Yazoo Kees zero turn. It has Hydro Gear ZT2800 pumps. I am getting ready to change the fluid in the pumps. I read in the owners manual and on Hydro Gear's website to use 20W50 motor oil in the pumps. My question has to do with the spin on filters on the ZT2800 pumps. Hydro Gear has filters for their pumps that are the exact same size as the Toyota filters that I use on my car. Since I'm using motor oil in my pumps and the Toyota oil filter screws right on, do you think there would be a problem using the Toyota oil filters on my Hydro Gear pumps instead of the Hydro Gear filters? I mean an oil filter is an oil filter, right?
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4796271
06/24/18 11:57 AM
06/24/18 11:57 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I never thought about that. I had a ZTR years back that had HydroGear ZT2800s on it, but I didn't own it long enough to change filters. I know at the time, aftermarket filters were available online pretty reasonably. Stens brand and others.
Make sure you can get the refill plugs and drain plugs loose before hand. I recall trying mine and those refill plugs were so tight I didn't think I'd get them loose. I got them out, never seized them and put them back in.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4796313
06/24/18 12:38 PM
06/24/18 12:38 PM
NC
Lancruza Offline OP
Lancruza  Offline OP
NC
Here is a pic showing two WIX filters. The 51394XP filter on the left is the WIX equivalent to the Toyota filter that I use. The WL10102 on the right is the WIX equivalent to the Hydro Gear HG52114 filter. The only differences between the two listed in the charts is that the filter material in the car filter is listed as synthetic and the trans filter is enhanced cellulose. Also the car filter has a by pass valve and the trans filter does not. Why would this not work?
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4796325
06/24/18 12:48 PM
06/24/18 12:48 PM
NC
Lancruza Offline OP
Lancruza  Offline OP
NC
Thanks for the reply JTK. I buy the OEM Toyota filters by the case. My cost is $4 each. I've used the Toyota filters for years on my vehicle and on my motorcycle(a 2009 Buell XB9SX). The filter works great on both. I'm trying to get an understanding why it will or will not work on my zero turn.
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4796352
06/24/18 01:17 PM
06/24/18 01:17 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
There is no reason why it won't work on those pumps.
Oil is oil and since you are using motor oil for the
re-fill, there is no reason not to use your filters.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4796446
06/24/18 03:07 PM
06/24/18 03:07 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Years ago when I was servicing a forklift I changed the trans oil filter and the one we have [PH8 type} screwed it on and was the same size and the line pressure couldn't be that much. Well I had a call back because the filter burst. Check
how strong the filter [burst pressure}has to be for the hydro unit.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: CT8] #4796465
06/24/18 03:33 PM
06/24/18 03:33 PM
NC
Lancruza Offline OP
Lancruza  Offline OP
NC
Thanks CT8. I think you've nailed the one aspect that I was missing...pressure. This will definitely lead me to by an OEM Hydro Gear filter. Much appreciated.
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4796508
06/24/18 04:37 PM
06/24/18 04:37 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
One other thing.... if you have a dirty hydraulic system, there's no way in Hades I'd run a filter with a true bypass valve, to let that junk recirculate through the pump. If you look at Wix 51365, which is spec'd for Subaru 4EATs, it has a small, wire-mesh filter in it instead of a true bypass valve. If the filter element itself becomes plugged, there will still be minimal flow through the screen which will stop particles from destroying anything else. It's probably a 50-micron mesh (guess, of course) but it's only purpose is to keep fluid flowing through the trans and chunks out of the trans... that's what I'd be cross referencing.
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4796595
06/24/18 06:24 PM
06/24/18 06:24 PM
Tennessee
sweezy722 Offline
sweezy722  Offline
Tennessee
I personally will not run a filter with a bypass on my hydro gear unit. I can replace the motor cheaper than 1 unit. My manual calls for 400 hour filter changes. Cheap insurance.
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4799467
06/28/18 07:26 AM
06/28/18 07:26 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
Last time I checked the filters for hydro gear are 10 micron, so you can't just slap an oil filter on it and call it good. This is like when chrysler put a 10 micron fuel filter on the bosch HPCR cummins injection pump and wondered why the injectors didn't last because bosch specified 4 micron minimum.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Filter for Hydro Gear ZT2800 - Toyota??? [Re: Lancruza] #4810071
07/10/18 09:42 AM
07/10/18 09:42 AM
VA
Gebo Offline
Gebo  Offline
VA
Stick with the OEM filter. I'm sure you noticed the API ratings for the 20w-50 oils. IDK but it seems like you need and old school 20w-50. Just check it out. I don't know. I'd call them for clarification but I am anal retentive.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Moderated by  ekpolk
