Reduce TORQUE to COMPENSATE for lubed threads?
Upper Midwest by the Lakes USA
Ram 1500 specs 135 ft lbs. but previous owner used neberseeze in lug studs. How much should I reduce toque on wrench? I will clean the threads as best as can with terry cloth but we must assume “some” residue.
For applications where it matters, they say many things.
IIRC I've seen recomendations ranging from 20 to 50% decrease.
But this isn't an application where it matters, so I get around the problem by not using a torque wrench in the first place. I tighten them as much as I can without hurting myself using one hand and a T-bar. If you're stonger than me (most people are) you might adjust the length of the T-bar to get something that seems reasonable.
I'd leave the antiseize where it can do its thing, though as a rule I use polythene sheeting torn from rubbish bags (with a little oil or grease) on wheel studs.
Use a wire brush, or, if you don't have one, an old toothbrush. That'll get enough off that you can just use the original torque.
Hard to say, but 20% is probably a good starting point.
I recommend cleaning off the anti seize.
With never seize I'd drop to 100 #'s. But you'll know when you start the nuts on by hand. Some studs are pretty rough and the never seize just fills in the pores/craters. They still feel like they have drag. On those I'd prolly go to the factory setting.
But if it feels smooth and buttery, you do not want to over stretch the stud and cause failure; so smooth feeling, 100 would be enough for me
And that's the way to know. Take a factory replacement stud and nut (new) and torque to spec w/o anything. Measure before and after. That's the stretch you are looking for. Now do it with never seize in increments. When you get the same stretch, that's your number. It's all about the stretch ...
Originally Posted By: Dave9
In that torque range I wouldn't sweat it, just leave the Never Seez on and torque to around 120.
Ditto. If worried, just check periodically. It'll take more than 120 to further tighten, but as long as the torque wrench still clicks at the 120 setting without spinning, then they haven't loosened, and are doing their job.
I use anti-sieze on plugs and torque to the low end of the range.
On a wheel, even torque is important.
I use a small amount of anti-on the wheel studs...
Drop 10 pound/feet is you like.
All good.
100 ft lbs is plenty - lugs will never loosen at that spec, lubed or not!
ARP website gives torques with and without lube.
Id clean, first with WD-40 since its cheap and available, then brake cleaner to get the remnant oils. Do so both on the studs and nuts.
If you go with a reduced number … come back to check them on the next weekend (after some driving) …
Yes, all about the strain (stretch), and that's the safest, most reliable measure.
I'd do exactly as you suggest, then work out how far you rotate it after tight to get the stretch...then get in a habit of "angle tightening" to the angle that you've developed.
When I get a new car with a torquespec, I work out the angle on dry studs, then repeat that with the wheel brace after I've applied antisieze.
Originally Posted By: i_hate_autofraud
"Lubed" and anti-seize are not the same, actual oil or grease, reduce torque 20%.
Actual anti-seize use spec torque.
How about polythene, the poor man's nylok?
