As another couple of options.
If you want to stay with a straight weight oil. Amsoil makes a full synth. SAE 30 designed as a diesel oil with a TBN of 12+ it would be perfect for a weekend use boat. The high TBN will help fight the nitration cause by the oil not getting to a proper operating temp.
Also the Amsoil 15w40 blend is a great value. I'm currently using this in my Triumph ST as a breakin-short run before I go to the full syn stuff. I'm only running it 3,000 or so.
