Hey Everyone,
This Toyota Previa 1991 had a new JDM engine installed last year. It ran 200 miles on Pennzoil Platinum 5-W30 immediately after the install. It was switched out with Redline 5W-30 and an ansoil EaO filter. This sample is after 1000 miles. Blackstone suggests changing out the oil and checking again after 1000 miles. The sump is huge, 6 quarts. I didn't want to wait after 3 quarts emptied to take a sample. I took a sample after 1.5 quarts had dropped, and the sample was taken after like 6 months of sitting (didn't start it). What do you guys think? They say the wear metals are high. Any suggestions on what I should look for in the engine? It did have slight surface rust on the cam lobes and crank case when installed. No running problems, and no noticeable oil burning in last 1000 miles.
