toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
70 registered members (ArrestMeRedZ, 87sammy, Antiquity, Ag76, 4WD, 7 invisible), 1,380 guests, and 21 spiders.
Topics300,293
Posts5,172,746
Members70,467
Most Online3,728
Jan 11th, 2020
Car damaging the alternator? #4783491 06/10/18 10:46 PM
Spetz Offline OP
Hi everyone,
About 6,000 miles ago (many years though) the alternator on my 6A12 MIVEC swapped Mitsubishi Mirage started failing. Unsure on history of the original alternator.
It was replaced with an aftermarket alternator which lasted 6,000 miles.
It started throwing an error code for FR terminal however was still usable and charging.
It also drained the battery but the car is rarely used so I would just disconnect the battery when not in use.
I replaced it with a second hand genuine alternator (23 years old to be fair) and the same error code was appearing (FR terminal).
At this stage I swapped in a spare ECU I had for the car, same issue.
I then had the genuine alternator rebuilt.
Upon installation it worked great. No errors codes, charging fine.
But it only lasted about a half hour and it stopped charging completely (not just an error code like previous alternators).
Is it possible something is damaging the alternator?
How would I test something like this?
2003 Mitsubishi Diamante 6G74. 165k miles.
Penrite HPR10 10W50, 12K km OCI
UOA:
https://www.bobistheoilguy.com/foru...ante-shu-5w40-1-2-can-mos2-7-8k-mile-oci
Re: Car damaging the alternator? [Re: Spetz] #4783506 06/10/18 11:56 PM
clinebarger Offline
How is it wired?...Do you have a diagram? Not sure a US market car is wired the same....
2001 Chevy Camaro L92/4L80E
Re: Car damaging the alternator? [Re: Spetz] #4783876 06/11/18 11:29 AM
A
Audios Offline
A
Check the ground cables, make sure there is no corrosion inside the cables, or feel them if they get warm/hot, theres a ground problem.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Car damaging the alternator? [Re: Spetz] #4783877 06/11/18 11:29 AM
A
Audios Offline
A
Also hows the battery?
Re: Car damaging the alternator? [Re: Spetz] #4784217 06/11/18 06:08 PM
Spetz Offline OP
The ground wire that goes from the negative battery terminal to the chassis?
I will check however from looking at it before it seemed fine.
The battery is new. It is a small battery though (the car is used only on the race track).
However the old alternator had a parasitic drain for a while which I just disconnected the battery when not in use.
UOA:
Re: Car damaging the alternator? [Re: clinebarger] #4784222 06/11/18 06:12 PM
T
talest Offline
T
I don't think they are, either.
It may or may not be, but is it like this ?
Re: Car damaging the alternator? [Re: Spetz] #4784279 06/11/18 07:16 PM
Spetz Offline OP
I am unsure how it is wired but there is a signal to and from the ECU.
So I believe the ECU controls it in a way.
However as mentioned I swapped ECUs thinking that might be the issue and it behaved exactly the same.
UOA:
Re: Car damaging the alternator? [Re: Spetz] #4791573 06/19/18 09:46 PM
clinebarger Offline
I was looking over some Mitsubishi diagrams, I used a 2003 Diamante for the example......
It appears the the ECM just monitors the "Lamp/Turn-on" for incorrect voltages (High/Low) & sends a data signal to the gauge cluster if a fault is present. The Cluster uses a transistor to control the Charging Lamp
The Generator Relay Coil is what passes a resisted ignition hot turn-on signal to the regulator.
