Originally Posted By: billt460
Originally Posted By: hatt
For $822 you can get a tactical model from Buds.
2 of mine are the Tactical Models. One blue, the other in Stainless. The nice thing about the tactical models, is mine came with 2, 20 round magazines, plus the rings. So when you factor in the cost of the rings and mags, it becomes a better deal.
My other Mini is a NRA Edition with the Hogue overmolded stock. The only thing I don't care for on the gun is the Ruger scope mounting system. It's OK, and I have never had any issues with mine, (either on the Mini or my Model 77 in .30-06). I just think there are better mounting systems available. (At least Ruger finally got away from those stupid slotted screws for the ring caps, and went to Torx's screws).
If I'm not mistaken, someone makes a scope mounting set up for the Ruger Mini 14 that incorporates a Picatinny Rail set up that attaches to the bases that are machined into the receiver. It allows you to use any Picatinny or Weaver type rings you want. It's a nicer set up because it allows you to vary the distance between the rings. With the Ruger set up, you're stuck with what they give you.
Ruger hurts you with mag prices. They want close to $40 for flimsy American mags. I decided to wait for Magpul to release the hunter stock instead of buying spare mags. $30+ mini mags is a tough pill to swallow. I like having a good supply of mags for autos. 2-3 mags will get me by with a bolt.
