Shelf life of synthetic 2 stroke engine oil ?
Colorado
I have a few unopened quarts of Mobil 1 synthetic 2 stroke engine oil that is about 14 years old.
Can it deteriorate or go bad? Or will it last indefinitely?
What type engine are you going to use it in?
A cheap piece of outdoor equipment or an expensive outboard motor on a boat?
In an expensive engine, I would buy new and not keep a large stock and just buy fresh when needed
This may not be a good answer but that is what I would do
If there isn't anything settled out on the bottom or a sludgey mess in the bottle, it is probably fine. If it has either of those things, don't put it in anything you're not willing to risk losing.
I think that your answer is a smart answer....
I will give you my address Sent them to me for disposal ! The oil is fine.
Originally Posted By: maxdustington
Sealed? Forever.
I would leave the bottle in the sun for a while and give it a really good shake before I used it.
I've got to ask; what is the purpose of leaving it in the sun for a while all about?
