Hey guys, I have a 1996 Ford Ranger V6 3.0L, and I'm having problems with a brake light. The driver's side brake light isn't responding when I push the brake pedal. The running light comes on when I turn the lights on, but the light doesn't brighten at all when I push the pedal. Passenger side brake lights work perfectly. I've already replaced all lights and fuses. I've tried wiggling the light switch and the turn signal switch with the pedal depressed but nothing changed. If it helps to know, my back-up lights do not come on at all and those lights and fuses have been replaced as well. Any ideas?
