I have a 2003 Dodge Caravan with 135,000 miles and the 3.3 liter V6. I bought a larger travel trailer with a heavier tongue weight. The back end of the Caravan sags pretty low when towing. Based on my reading, I can fix this with air shocks or something called a Timbren suspension unit. The Timbren is a stack of rubber discs running between frame and axle. The discs are supposed to compress easily at first then give higher resistance with heavier loading. I like the apparent simplicity of the Timbren units.
Has anyone used Timbren units? If so, how did they work for you?
Thanks in advance for any advice.
