Anyone know how to completely replace/flush coolant on a Chrysler 4.0L SOHC engine? It's essentially the same as the 3.5L SOHC. Should I just pull the block and radiator plugs, and simply replace the coolant that's drained? Or is a more elaborate flush recommended, and how would I go about that. Should I remove the thermostat when I'm doing all this?
I normally just do a drain and refill on my vehicles, but this one is at 130k and it's never had a coolant change. That's a good and a bad thing, at least it means nobody screwed it up by putting a universal / off-color coolant in. I plan on using Zerex G05 or some other chemically-compatible HOAT like Pentosin that's the OEM pink color.
