Hi all. first time caller long time listener.
Vehicle - 2008 BMW 500i M-Sport. N62 V8 normally aspirated engine, 75k miles
BMW Recommended - API SM or greater, Castrol 5W-30 or 5W-40. And the ubiquitous LL01.
Fuel Recommended - Top Tier 91 Octane. I can't get 91 octane ethanol free gas around here but I can get 90 octane so I fill with 2/3rds 90 octane ethanol free and 1/3 93 octane ethanol polluted. Gets me 91 Octane and 3% corn.
At the last oil change I sent a sample off to Blackstone and my numbers were much better than norm.
I like to change at least every 5K miles.
The car is new to me but was previously taken very good care of. I assume previous owner ran BMW or Castrol 5W-30.
I'm in central florida, it's flat and rarely if ever freezes - maybe once a year for a few hours. This time of year the daily temp is 75-90 and will only get warmer over the next few months.
Car is my daily driver.
Commute is 20 minutes on mostly highway with light traffic. In the evenings, 35-40 minutes, same highway but stop and go traffic.
I drive easy during the week. Transmission in Drive mode which is the economy mode. But on the weekends a shift to Sport mode and drive quick and fast.
Did I leave anything out?
My question is about weight. I switched to 5W-40 thinking I needed the 40 because of the climate. But I've read that since the motor oil gets to 100 C pretty quick the 40 isn't really necessary solely for climate reasons. And I've also read that the wider the gap between Winter and Hot weights the larger the additive package and thus the smaller the base oil percentage. I see a lot of people running 0W but I've got no need for cold protection. So first is my thinking correct? Might I even consider 10W-30? Oil is free through FCPEuro so as long as they sell it that's what I use. Currently using Ligui Moly Leichtlauf High Tech 5W-40. It meets specs.
My wants are:
1) Protection. Whatever makes engine lasts longer. Particularly valve seals.
2) Performance. If it shaves a tenth of a second off of 0-60 times I'm all for it.
3) If one and two or met then Fuel Economy
What I couldn't care less about:
1) Any tree-hugger concerns.
2) Long Life. I'm changing at 5k miles so I don't need additives to make it longer lasting.
Side question. I assume that I want the highest HTHS I can get. Is that correct considering my concerns?
I'll hang up and listen.
My wants are:
