Originally Posted By: JC1
If you are only going to buy one, buy one with the Cable.
I have a pair like you show, but they can slip a lot. I also have two different needle nose Vicegrips which work better since they can lock on and then allow you to slide the clamp off.
And don't buy a cheap chinese brand. I've heard they can break after one or two uses.
The ones I posted lock, and their are solid enough that you do not have to be worried about them coming loose when you are yanking on the clamp. I wish I had gotten them sooner, the reason I have hated those constant tension clamps is because I did not have the right tool for the job.
