Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
114 registered members (2K2AcuraTL, ABerns, AP9, ARCOgraphite, 92saturnsl2, 853okg, 11 invisible), 2,259 guests, and 66 spiders.
Topics286,024
Posts4,901,070
Members67,549
Most Online2,967
Mar 10th, 2019
Topping Up CV Joint Grease #4786341
06/14/18 12:55 AM
06/14/18 12:55 AM
Saskatchewan, Canada
Gannet167 Offline OP
The clamps on my CV Joints have come loose and grease has leaked out. The joints and boots are still fine. I want to add hear and new clamps. The vehicle is a 2004 4Runner. I believe they are original cv joints.They don't get torque applied to them very often as I'm usually in 2wd.
I have a fresh tube of Amsoil Polymeric in my grease gun. It's 5% moly and according to Amsoil website "combines an over-based calcium-sulfonate complex thickener and proprietary synthetic polymeric technology". Assuming what's in the cv joint currently is lithium based, this could be compatible.
Would it work in the outer cv joint? Would I be better off to buy a few tubes of Toyota oem outer cv grease? Or buy another grease gun for some valvoline or Red Line Cv2?
Should I use this or anything else on the Inner joint? I see a lot of people using a polyeurea in inner joints. But it's incompatible with basically everything so I'd need to be sure of what's in there now.
My other grease gun has red synthetic NLGI2 non moly grease.
Re: Topping Up CV Joint Grease [Re: Gannet167] #4786394
06/14/18 05:26 AM
06/14/18 05:26 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would push the boot back, clean the joint and the inside of the boot as well as I could and use the Amsoil.
Use half a tube (7oz) on the outside joint then clamp it up tight. Wipe the clamping surface on the joint and inside of the boot carefully with a rag soaked in brake cleaner to insure its clean and wont slip.
Re: Topping Up CV Joint Grease [Re: Gannet167] #4786678
06/14/18 01:03 PM
06/14/18 01:03 PM
CA
The Critic Offline
The Critic  Offline
CA
Supposedly, Amsoil no longer markets a grease that is suitable for use in CV joints. I would use Redline CV grease.
Given the age of the vehicle, it may make sense to remove the axles and install new boots. Toyota makes a really nice CV Boot Kit for around $30/boot.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: Topping Up CV Joint Grease [Re: Gannet167] #4795952
06/24/18 04:56 AM
06/24/18 04:56 AM
NY
DAC2018 Offline
DAC2018  Offline
NY
if you're going to replace boot check out High Angle CV Boot Kit!
http://www.offroadsolutions.com/tech-info/high-angle-cv-boot-kit/
