seat belt retracts slowly
by NH73 - 05/28/20 05:19 AM
Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
48 registered members (2K2AcuraTL, AZjeff, Astro14, Boxnuts, BlakeB, 87sammy, 4 invisible), 1,185 guests, and 57 spiders.
Topics305,960
Posts5,283,680
Members71,546
How copy an existing stair stringer?? #4785736 06/13/18 10:28 AM
E
edwardh1 Offline OP
E
Outside wooden steps from a small porch, front door down to ground , 5 steps, last step is just about down on the ground level.
last foot that sits in/ on the cement pad that is in the soil has fair amount of rot. 34 years young.
I want to make a copy of the stringer and sister (with nails or bolts) it (or now that I think of it, sister the bottom half. none of it is visible.
whats the best material to get a fair pattern match? I dont know if I can do the rise and run thing with a framing square but maybe I can, on a 2x12.
I made a poster paper copy thats fair, whats next up fpr pattern material cardboard? I need a good pattern as quality 2x12 treated is expensive
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785799 06/13/18 11:37 AM
PimTac Offline
I saw it done once using a roll of butcher paper. They traced the pattern and used thumb tacks to secure the paper. Tape would work as well but you need two stringers. Trace off of the same pattern.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785815 06/13/18 11:50 AM
A
ARCOgraphite Offline
A
I laid the old one on the new board.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785826 06/13/18 12:05 PM
M
maxdustington Offline
M
You plan to just slap a second stringer to reinforce the first one? You are going to have to change the joist hanger anyway, so if you could pull the old one out and copy it that would be best. However, you may as well just replace it at that point.
I am not sure that you could get a good pattern while it was in place and if you are going to cut a stringer why not just cut a new stringer and do the job correctly?
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785854 06/13/18 12:37 PM
PimTac Offline
I misread the original post. You say you want to sister the new stringer onto the old?
I would not do this. Get rid of the old and go with new stringers. Also, take care of the ground exposure at the bottom.
2017 Mazda CX5
Roki OEM filter.
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785900 06/13/18 01:19 PM
A
AandPDan Offline
A
Re: How copy an existing stair stringer?? [Re: ARCOgraphite] #4785916 06/13/18 01:38 PM
E
edwardh1 Offline OP
E
OLD one is still in place
Re: How copy an existing stair stringer?? [Re: edwardh1] #4786170 06/13/18 07:32 PM
spasm3 Offline
https://www.homedepot.com/p/5-Step-Groun..._-301040023-_-N
You could buy all three , or buy one and copy it onto pressure treated lumber.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: How copy an existing stair stringer?? [Re: edwardh1] #4786268 06/13/18 09:43 PM
W
Wolf359 Offline
W
Get the book and do your own. Uneven steps are a trip hazard. Normally you're supposed to measure them out so that the rise for all the steps are uniform. You don't really get that with pre-made stringers as the top or bottom may be too high/low. And yes, you should use joist hangers, that's usually code in most places.
https://www.amazon.com/Advanced-Stair-Stringer-Layout-Methods-ebook/dp/B007URAYO8
Oh and as for trip hazards, I know one landlord that lost a case when a tenant fell on the steps. Said it cost him 60k, 30k for the tenant and 30k for the lawyer. Automatic loss for him as he had uneven steps. Code here is that you're not supposed to have more than 3/8 inch variation in step height. If you measure the whole distance and divide it out, they should all be uniform in height. There's a reason why if you go to a commercial/government building, every step you encounter will be uniform in height. (if not, trip and sue... laugh )
