2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Tiger shark oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
2016 Civic 2.0. Strange driving habits. Which oil?
by DEEPfrom1. 02/23/19 12:03 PM
Mercedes OM617 3k Chevron Delo
by gonesurfing. 02/23/19 11:38 AM
Water Pump Replacement Question
by Gebo. 02/23/19 10:55 AM
Maxx Oil ?
by lawnguy. 02/23/19 10:54 AM
Pure Vermont Amber Rich Maple Syrup
by Vern_in_IL. 02/23/19 10:11 AM
Regarding Mechanics
by Snagglefoot. 02/23/19 09:47 AM
Barrett, Beez1204, vmasse, zorba02, Ecodiesel
67326 Registered Users
119 registered members (2002 Maxima SE, 2oldtommy, 1WildPig, aircooled, 16 invisible), 2,091 guests, and 55 spiders.
Topics284,720
Posts4,875,802
Members67,326
Most Online2,548
Feb 16th, 2019
Network Ports - How Can I Check Status? #4786150
06/13/18 06:04 PM
06/13/18 06:04 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
How can I tell if the following network ports are open and functional?
The latest version of "Dell SupportAssist" doesn't work and I'm trying to figure out why. Previous version worked, so wondering if maybe the network port requirements might be the issue.
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4786154
06/13/18 06:10 PM
06/13/18 06:10 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
do you have any kind of internet security/firewall installed?
what router are you using.
Re: Network Ports - How Can I Check Status? [Re: Rand] #4786157
06/13/18 06:13 PM
06/13/18 06:13 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
Yes, Windows 7 with firewall enabled. Using a CenturyLink modem.
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4786204
06/13/18 07:07 PM
06/13/18 07:07 PM
USA
mk378 Offline
mk378  Offline
USA
The modem-router by default will have all ports open for outgoing connections and all ports closed to incoming connections.
If these are outgoing connections you may need to do something in windows firewall.
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4786263
06/13/18 08:40 PM
06/13/18 08:40 PM
CA
spackard Offline
spackard  Offline
CA
If those are incoming ports that need to be open, you can scan yourself with something like:
https://www.whatismyip.com/port-scanner/
More difficult to test outgoing. The way I'd do it is install DU Meter, then look if the software in question is connected to those ports on whatever host(s) Dell runs that the software connects to.
Just difficult to read the "View network connections..." "Open TCP Connections" for non-professionals, or maybe not.
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4786294
06/13/18 09:26 PM
06/13/18 09:26 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
Are these ports controlled in the modem settings? Where is it that they can be enabled or not?
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4786299
06/13/18 09:29 PM
06/13/18 09:29 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
The software only calls out, and I doubt there is anything blocking those ports outgoing, given the device you are using. Is this the most recent version of the program from the Dell support site? I generally dislike those programs for a variety of reasons, but why do you think you need it?
2019 RAM 1500 Sport
2016 Grand Cherokee SRT
Re: Network Ports - How Can I Check Status? [Re: OVERKILL] #4786318
06/13/18 10:24 PM
06/13/18 10:24 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
Yes, it's the latest version of "Dell SupportAssist". Like said earlier, the previous version worked fine. SupportAssist actually did an auto-update, wasn't my choice - there's probably a setting I can change to make it not auto-update.
SupportAssist is actually kind of handy because it runs based on my specific machine (ie, tag number) and knows if I have outdated drivers, BIOS, etc. It also has a bunch of diagnostic tools for memory, HD, monitor, etc.
I even uninstalled the non-working SupportAssist and went to Dell's website to do a fresh install which looked to go well, but it still doesn't load when I launch it.
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4786506
06/14/18 07:46 AM
06/14/18 07:46 AM
NC
BigD1 Offline
BigD1  Offline
NC
You really don't need SupportAssist.
You can get all those drivers, bios updates, and etc. from just going to the Dell website, and entering the tag number.
It's been a while since my last Dell. It should have a hidden partition that the Dell software uses to set the machine back to as it came from the factory. My memory is fading on this one, but I recall that it was accessed with a function key. Dell should have instructions on how to recover to factory on their website.
You might have a recovery disk that came with the Dell that has the imaging software/recovery on it.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Network Ports - How Can I Check Status? [Re: BigD1] #4786713
06/14/18 12:58 PM
06/14/18 12:58 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
True, I probably don't need half the software on my computer. But I did like some of the features SupportAssist provided.
I don't need to recover anything really - got way too many updates, etc on this computer to start from scratch. It's just that the new version of SupportAssist doesn't work on my computer, even though it meets all the requirements for the software to work. I think Dell has an installation bug or code issue going on with the new version since the auto update and my fresh manual installation both don't work.
Re: Network Ports - How Can I Check Status? [Re: spackard] #4787567
06/15/18 02:24 PM
06/15/18 02:24 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
I used that port scanning tool and it says all those ports I listed in my first post were "closed" when the tool is using my "Public IPv4 Address".
So I'm wondering if that's the issue, or is it something else? I would think that the installation program from Dell would check or configure ports that were required.
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4788140
06/16/18 08:43 AM
06/16/18 08:43 AM
Ontario, Canada
Ontario, Canada
No, those ports are supposed to be closed to the outside world. As long as the software can get OUT, that's what matters, and those tools do not check for that.
2019 RAM 1500 Sport
Re: Network Ports - How Can I Check Status? [Re: ZeeOSix] #4788511
06/16/18 06:10 PM
06/16/18 06:10 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Another great place to check ports and find all kinds of resources is at grc.com.
Plain, simple Garak.
Re: Network Ports - How Can I Check Status? [Re: OVERKILL] #4788534
06/16/18 06:39 PM
06/16/18 06:39 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
How can I tell if ports 5700, 9012, 8883, 8884, 8885 & 8886 are "open" for outgoing?
Re: Network Ports - How Can I Check Status? [Re: Garak] #4788640
06/16/18 08:29 PM
06/16/18 08:29 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
I went there, and I'm assuming you are talking about their tool called "SheildsUP", the link is located down about 2/3 down from the top of this page: https://www.grc.com/default.htm
I ran most of the SheildsUP tests, and it showed that all my ports are in "Stealth" status. Apparently this means the ports don't show up as "existing" to the outside world ... but I'm not sure if that also means it could be closed, but in a "Stealth" way.
https://www.grc.com/su/portstatusinfo.htm
I also did a custom 'port probe' on ports 5700, 9012, 8883 thru 8886 and all show up as "Stealth".
Moderated by  ekpolk
