Topics284,723
Posts4,875,824
Members67,326
Most Online2,548 Feb 16th, 2019
Re: PZ 173 CUT OPEN
[Re: 53' Stude]
#4786060
06/13/18 04:17 PM
06/13/18 04:17 PM
Posts: 3,845 Wet side WA
JohnnyJohnson
Wet side WA
Looks like someone had been running coco through that filter.
2004 Corolla 129202 Out: VML 5w-30 TG4967 OCI 5007 Miles In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18 2006 Duramax 74645 Out: T6 5W-40 M1-303 In: T6 5W-40 XG9100 73705 4-22-18
Re: PZ 173 CUT OPEN
[Re: 53' Stude]
#4786066
06/13/18 04:23 PM
06/13/18 04:23 PM
Posts: 10,279 Kendall, FL
wemay
Kendall, FL
Looks good. Louvers appear large and far from blocking flow. Pleats don't look bad either. Not bad for a jobber filter.
18 Sportage 2.4 AWD Now: VAL Syn 5w20 / OEM 26300-35504 Next: HAV Syn 5w30 / K&N HP-1004
13 Santa Fe Sport 2.0T Now: PP 5w30 / WIX 51334 Next: QSUD 5w30 / Same
Re: PZ 173 CUT OPEN
[Re: wemay]
#4786075
06/13/18 04:37 PM
06/13/18 04:37 PM
Posts: 12,283 In the shop
53' Stude
OP
OP
In the shop
Looks good. Louvers appear large and far from blocking flow. Pleats don't look bad either. Not bad for a jobber filter. Yeah louvers look good
Re: PZ 173 CUT OPEN
[Re: 53' Stude]
#4786078
06/13/18 04:39 PM
06/13/18 04:39 PM
Posts: 10,081 1/2 hr N.E. of Detroit
Triple_Se7en
What is a PZ filter..... Pennzoil?
2019 Hyundai SantaFe 2.4 factory fill / QS 5w20 conv. / Mahle OEM oil filter 04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter 03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: PZ 173 CUT OPEN
[Re: Triple_Se7en]
#4786080
06/13/18 04:40 PM
06/13/18 04:40 PM
wemay
Kendall, FL
What is a PZ filter..... Pennzoil? Yes.
Re: PZ 173 CUT OPEN
[Re: 53' Stude]
#4786088
06/13/18 04:54 PM
06/13/18 04:54 PM
Posts: 5,785 Virginia
bbhero
Virginia
Does look good Captain. This made by Purolator correct if I'm right. You add a lot of great information and pictures on here. Thank you for all you do.
Nissan Altima 3.5 Coupe Mobil Super 5w30 Wix 57356 "Treat your family like your friends and treat your friends like your family."
Re: PZ 173 CUT OPEN
[Re: bbhero]
#4786102
06/13/18 05:07 PM
06/13/18 05:07 PM
53' Stude
OP
OP
In the shop
Does look good Captain. This made by Purolator correct if I'm right. You add a lot of great information and pictures on here. Thank you for all you do. You're welcome hoss  Hope your taking care of the girlfriend and "the boss"
Re: PZ 173 CUT OPEN
[Re: 53' Stude]
#4786256
06/13/18 08:27 PM
06/13/18 08:27 PM
Posts: 7,618 Planet Earth
2015_PSD
Planet Earth
Cuts in ADBV? Purolator...
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo 2018 Mercedes Benz C300 2.0L Turbo 2015 Ford F-250 Platinum 4WD 6.7L PSD
