Originally Posted By: mvent
My wife's accord has been dealer serviced since new, oil changed at 20% on OLM or sooner, seemed to go down very little between changes, last oil change around 36k miles I decided to do it myself, went with Mobil1. 0w-20 and Honda filter. Checked oil after close to 3k miles and 60% OLM and had to add 1.5 quarts. Is there a problem with these engines or just the way it is?
TIA
Some use oil unfortunately and some don't. You could try a different brand of oil, or bump it to a 0W30 or a 5W30 and see what happens. Some would suggest you wait until after the warranty is up to bump it to a 30 grade. If you were to go back to Honda and complain about having to add oil, odds are they'll have a story for you about it being acceptable, assuming you don't have a leak, and send you packing.
