Extreme fuel dilution
by BigShug681. 02/23/19 04:52 PM
Nine PH3600-size filters FS
by SubieRubyRoo. 02/23/19 04:45 PM
2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Jeep Cherokee 2.4L oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
2016 Civic 2.0. Strange driving habits. Which oil?
by DEEPfrom1. 02/23/19 12:03 PM
Mercedes OM617 3k Chevron Delo
by gonesurfing. 02/23/19 11:38 AM
Water Pump Replacement Question
by Gebo. 02/23/19 10:55 AM
Maxx Oil ?
by lawnguy. 02/23/19 10:54 AM
snapy907, Barrett, Beez1204, vmasse, zorba02
67327 Registered Users
109 registered members (2002 Maxima SE, 1WildPig, 2004tdigls, 2oldtommy, 240_Ed, 13 invisible), 1,956 guests, and 54 spiders.
Topics284,723
Posts4,875,824
Members67,326
Most Online2,548
Feb 16th, 2019
Oil filters for outdoor power equipment #4785955
06/13/18 01:54 PM
06/13/18 01:54 PM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
Recently bought a new zero turn mower with the Kawasaki FR730V motor. Changed the oil and filter with less than 10 hours on it. Not wanting to pay the $10 plus dollars for the OEM filter or even an aftermarket filter in that exact size (Kawasaki 49065) I did a quick search and Fram 3614 was a suitable replacement. I put that on but prefer to run WIX filters and today did some more research to decipher the beta ratio numbers on their website and if the filter I was using was indeed correct and not just following what other people do.
It really makes me wonder why certain filters are even used when better filters (at least by the filtering capability) are more available and cheaper. Here is what I found.
Wix 57035 is the direct replacement for the OEM filter and is $6.85 on RockAuto. Wix 51348 is the cross reference to Fram 3614 and is $4.26.
OEM Specs
Gasket OD 2.75"
Height - 2.375"
Micron 25/30 (This was from a parts website and couldn't find anything from Kawasaki's website)
Wix 57035
Gasket OD 2.734"
Height - 2.305"
Beta Ratio - 2/20=20/41
Relief pressure 8 psi
Wix 51348
Gasket OD 2.734"
Height - 3.404"
Beta Ratio - 2/20=6/20
Relief pressure 8-11 psi
Found a review on Amazon of all places explaining the beta ratio numbers - 2/20 is plugged into this formula twice. 1-1/x
1-1/2 = 50% and 1-1/20 = 95%. The second set of numbers is the micron size of the particle trapped at that percentage. So in this case of the Wix 51348 50% of 6 micron particles are trapped and 95% of 20 micron particles are trapped.
OEM is then 50% of 25 micron particles and 95% of 30 micron particles are trapped (if the 2/20 is the same)
Wix 57035 is 50% of 20 micron and 95% of 41 micron particles are trapped
Wix 51348 is 50% of 6 micron and 95% of 20 micron particles are trapped
If you are still reading am I missing something that the car filter, Wix 51348, fits, has the same bypass pressure, filters better, has more filtering media and is cheaper? Unless there are some applications that don't allow space for longer filters why even use the 57035? Is it constructed better?
Think twice, speak once.
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4785973
06/13/18 02:26 PM
06/13/18 02:26 PM
USA
smithph Offline
smithph  Offline
USA
Here is a link to Bill Kapaun's list that he started over 10 years ago, it is toward the bottom of the thread. I think the MC FL793 has largely been replaced with the FL910s
https://www.bobistheoilguy.com/forums/ub...ers#Post4686013
Fear, uncertainty and doubt are excuses to do nothing!
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786006
06/13/18 03:05 PM
06/13/18 03:05 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
You're overthinking it. Pick a filter and go with it. I have over 3,000 hours on a Kawasaki FD620V. I change the oil and filter every 100-125 hours with Rotella 10w-30.
What filters have I used over the past 15 years? Mainly 3 models of filter, and nothing over $4. W*M SuperTech, NAPA ProSelect, or O'Reilly MicroGard.
At various time through history, those filters have all been the same entry-level filter, sourced from Wix.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786037
06/13/18 03:41 PM
06/13/18 03:41 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
FL910s is good for a few hundred hours and cheap with no shipping fees.
Plus has the Silicone adbv.
"If I walked on water, they'd say I couldn't swim."
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786053
06/13/18 04:06 PM
06/13/18 04:06 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
You could cut the OE filter open to see how dirty it is and the construction.
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786062
06/13/18 04:18 PM
06/13/18 04:18 PM
Virginia
mattwithcats Offline
Virginia
Take a look at a Wix 51516 or Wix XP 51516...
$3.72 for 51348
$3.67 for 51516
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786067
06/13/18 04:23 PM
06/13/18 04:23 PM
wv
krismoriah72 Offline
wv
Here is a thread with the same question from a few yrs ago.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3696818/Re:_oil_filters_for_kawasaki_F
Re: Oil filters for outdoor power equipment [Re: Zee09] #4786100
06/13/18 05:05 PM
06/13/18 05:05 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I also use the MC FL910 on my Craftsman riding mower.
2007 Ford Fusion 237,000 miles
M1 0-20 EP
2017 Ford Fusion 64K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786136
06/13/18 05:44 PM
06/13/18 05:44 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
Baldwin Filters has an excellent application tool if you want to try that. Baldwin filters are available at Zoro Tools and other online sellers. I've used them for my Snapper 24 HP (Briggs), a Kawasaki 19 HP on a Wight ZTR and a Generac GT-990 twin on a standby generator. Solme complain about Baldwin quality since the company was sold, but I haven't seen the evidence.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786291
06/13/18 09:21 PM
06/13/18 09:21 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Not that I currently have any, but if I ever do get any OPE that requires an oil filter, I plan on getting a Fram Ultra/Wix Platinum and never changing the filter again.
There have been several examples posted of Ultra's being used for 200+ hours still looking almost brand new.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786672
06/14/18 11:48 AM
06/14/18 11:48 AM
MB - Manitoba
FastLane Offline
FastLane  Offline
MB - Manitoba
Why not Fram PH7575? Thats what I use on my JD STX38. 7575 is meant for a small engine. The 3614 is meant for a car.
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4786681
06/14/18 12:06 PM
06/14/18 12:06 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
On my 2002 model year ExMark Lazer Z HP with the 21hp Kawasaki I run an Ea15k09. I only have 550hrs on the mower so far Change the oil and filter at the end of every cutting season.
2002 Silverado 5.3 0w-20 AMSOILģ
Re: Oil filters for outdoor power equipment [Re: SVTCobra] #4787080
06/14/18 09:04 PM
06/14/18 09:04 PM
Georgia
MParr Offline
MParr  Offline
Georgia
Iím using a Fram Ultra XG4967 on my Toro. Iíll probably continue to use the FU or a WIX/NAPA filter. You canít go wrong with either. Plus they are cheaper than the Toro OE filters.
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Moderated by  ekpolk
