Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
42 registered members (bbhero, askani79705, Black_Thunder, 928, adams355, 4 invisible), 1,618 guests, and 18 spiders.
Topics300,654
Posts5,180,397
Members70,544
Page 1 of 3 1 2 3
2018 Honda Civic 1.5l Turbo: octane? Oil? #4785849 06/13/18 11:31 AM
F
Finz Offline OP
F
Ended up leasing the civic I posted about previously... Sedan with 6 speed manual. Car is an absolute blast to drive, and Iím in the 500 mile neighborhood
This engine, 1.5l turbo, has lots written about on here and Civic/CRV forums so I have 3 questions in an effort to get as close to a final/correct answer as possible:
1. Many threads about using 91 octane vs owner manualís 87 octane to combat fuel dilution. I canít figure out how or why a higher octane would help....? Thought octane was relative to compression (only).
2. Iím going to disregard mm and change factory fill early... I figured at 1k miles. Is that a good number? sooner? Later? Prolonged exposure to a higher moly constant has been discussed.... I have a can of Lubriguard Moly lying around if that might help
3. With regard to fuel dilution, plan on oil changes every 5k. Lots of very short trips in this carís future. Many have suggested a heavier weight oil to help combat the fuel dilution. Car calls for 0W-20. I have a jug of Mobil European Formula at 0W-40. Is that too steep of a jump right off the bat? Ever? I know a turbo can be taxing on the oil as well.
Thank you for any input
óbob
God Bless America
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785855 06/13/18 11:37 AM
R
racin4ds Offline
R
If you're leasing it then you're not worried about it lasting nor are you planning to keep it so I'd just use whatever the OM tells you to. IF you plan to keep it long term and want it to last, I'd ignore the OM and run a 5W30 and being its a turbocharged engine with high compression, I'd never run less than 91 octane, anything less is just stupid!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785857 06/13/18 11:40 AM
CT8 Offline
Doing any maintenance on a lease is foolish.
2015 F150 2.7
2018 F350 6.2
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: racin4ds] #4785861 06/13/18 11:42 AM
F
Finz Offline OP
F
Thanks Racin... I know Iím leasing but want the next owner to be assured it was well kept and I donít mind oil changes
So you feel the 0W-40 is no good?
being its a turbocharged engine with high compression. Why do you say this...? I assumed the all high compression engines called for higher octane. This car indicates 87 is fine (Sport and SI might be different)
God Bless America
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785868 06/13/18 11:50 AM
wemay Offline
Sweet car with a manual transmission! Congrats. I would let the dealership take care of the oil changes on a lease. There is a member on here running 0W-40 though... he seems to like it.
IF i were to own one, i'd stick to 0W20 and follow the OLM and conduct a few UOA. If, after 3-4 UOA, the report showed accelerated wear, i'd bump up to 0/5W30. But also remember, initial UOA on a new car show more wear metals than after break-in.
2019 VW Passat Wolfsburg TSI - Castrol Edge Professional LL IV FE 0W-20, OEM
2013 Hyundai Santa Fe Sport 2.0T - Mobil1 Annual Protection 5W30, M1-104
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785870 06/13/18 11:53 AM
J
JustN89 Offline
J
Not necessarily, no. I also wouldn't exactly call the Civic a high compression engine either being at 10.8:1. The 2018 Elantra (2.0L) runs at 12.5:1 compression and doesn't require anything other than 87 octane.
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785872 06/13/18 11:54 AM
rooflessVW Offline
On a lease I didn't intend to keep I would run the cheapest oil and fuel I could find.
On a purchase or lease or I intend to keep I would run Top-Tier premium fuel and 0W-40.
"Zed's dead baby, Zed's dead."
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785876 06/13/18 11:57 AM
B
Bottom_Feeder Offline
B
I'd like to know this also.
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785883 06/13/18 12:01 PM
Mr Nice Offline
Leasing = follow the OLM.
No need to worry.
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Mr Nice] #4785898 06/13/18 12:19 PM
F
Finz Offline OP
F
Thanks for all the input. Let me ask this another way (disregard the fact Iím leasing):
* When is a good time/mileage to replace the factory fill?
* Does a high octane gas help with fuel dilution on a car that calls for 87 octane? How?
* Would a 0W-40 be overkill in a civic in an effort to mitigate fuel dilution? Car calls for 0W-20 but I have a jug of 0W-40
I appreciate the responses so far...
Thanks again
God Bless America
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785904 06/13/18 12:24 PM
SatinSilver Offline
In the 2018 Civic Hatch Sport and Sport Touring model Honda states that premium fuel is recommended. Same engine but has 10 more HP and a different exhaust or at least the tailpipe is different. If you notice the oil level increasing I would switch to premium. Premium seems to keep it under control. One of the biggest complaints with on www.carcomplaints.com is the increasing oil level with the 2017 CRV which has the same engine.
Also time to update your signature line. smile
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: SatinSilver] #4785906 06/13/18 12:29 PM
F
Finz Offline OP
F
Originally Posted By: SatinSilver
In the 2018 Civic Hatch Sport and Sport Touring model Honda states that premium fuel is recommended. Same engine but has 10 more HP and a different exhaust or at least the tailpipe is different. If you notice the oil level increasing I would switch to premium. Premium seems to keep it under control. One of the biggest complaints with on www.carcomplaints.com is the increasing oil level.
Ha...! Fixed signature....(forgot all about it)
Any idea why premium would help with increased oil level/Fuel dilution?
Iím not arguing itís apparent effectiveness.... just tying to understand how/why
God Bless America
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785911 06/13/18 12:36 PM
SatinSilver Offline
Not sure and haven't looked into it. Lately I've been using premium in the Matrix because the power seemed down. I looked at the owner's manual and it stated use 87 or higher. It said something else about using premium but can't remember the exact verbiage. I know acceleration is much quicker and people aren't raising their hands gesturing about accelerating too slow. Now I can pull away from them. This is Shell Or BP 93 octane since they don't have 91. Just 87-89-93. I could floor it on 87 but really don't want to do that.
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785930 06/13/18 12:49 PM
P
parshisa Offline
P
91/93 octane + good synthic=good engine health (low FD and wear numbers)
Re: 2018 Honda Civic 1.5l Turbo: octane? Oil? [Re: Finz] #4785939 06/13/18 01:19 PM
R
racin4ds Offline
R
Any engine over 10.5:1 is relatively high compression then you add forced induction on top, absolute MIN octane should be 91 octane! These OEM's detuning these cars just to say they can run 87 junk is ridiculous! If you OP for the turbocharged option you had better be ready to buy premium fuel, plain and simple.
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Page 1 of 3 1 2 3
