NY Yankee fans...
by gfh77665 - 10/20/19 12:56 AM
168 inch pounds feels really--really tight
by perfect_oil - 10/19/19 11:36 PM
Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
25 registered members (Char Baby, Drosselmier, Donald1953, BlakeB, cjcride, 2 invisible), 630 guests, and 20 spiders.
Topics296,198
Posts5,093,331
Members69,612
Most Online3,532
Jul 30th, 2019
How copy an existing stair stringer?? #4785736 06/13/18 10:28 AM
E
edwardh1 Offline OP
E
Outside wooden steps from a small porch, front door down to ground , 5 steps, last step is just about down on the ground level.
last foot that sits in/ on the cement pad that is in the soil has fair amount of rot. 34 years young.
I want to make a copy of the stringer and sister (with nails or bolts) it (or now that I think of it, sister the bottom half. none of it is visible.
whats the best material to get a fair pattern match? I dont know if I can do the rise and run thing with a framing square but maybe I can, on a 2x12.
I made a poster paper copy thats fair, whats next up fpr pattern material cardboard? I need a good pattern as quality 2x12 treated is expensive
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785799 06/13/18 11:37 AM
PimTac Offline
I saw it done once using a roll of butcher paper. They traced the pattern and used thumb tacks to secure the paper. Tape would work as well but you need two stringers. Trace off of the same pattern.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785815 06/13/18 11:50 AM
A
ARCOgraphite Offline
A
I laid the old one on the new board.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785826 06/13/18 12:05 PM
M
maxdustington Offline
M
You plan to just slap a second stringer to reinforce the first one? You are going to have to change the joist hanger anyway, so if you could pull the old one out and copy it that would be best. However, you may as well just replace it at that point.
I am not sure that you could get a good pattern while it was in place and if you are going to cut a stringer why not just cut a new stringer and do the job correctly?
97 GMC RCLB K2500LD L30/4L60
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785854 06/13/18 12:37 PM
PimTac Offline
I misread the original post. You say you want to sister the new stringer onto the old?
I would not do this. Get rid of the old and go with new stringers. Also, take care of the ground exposure at the bottom.
2017 Mazda CX5
Roki OEM filter.
Re: How copy an existing stair stringer?? [Re: edwardh1] #4785900 06/13/18 01:19 PM
A
AandPDan Offline
A
Re: How copy an existing stair stringer?? [Re: ARCOgraphite] #4785916 06/13/18 01:38 PM
E
edwardh1 Offline OP
E
OLD one is still in place
Re: How copy an existing stair stringer?? [Re: edwardh1] #4786170 06/13/18 07:32 PM
spasm3 Offline
https://www.homedepot.com/p/5-Step-Groun..._-301040023-_-N
You could buy all three , or buy one and copy it onto pressure treated lumber.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: How copy an existing stair stringer?? [Re: edwardh1] #4786268 06/13/18 09:43 PM
W
Wolf359 Offline
W
Get the book and do your own. Uneven steps are a trip hazard. Normally you're supposed to measure them out so that the rise for all the steps are uniform. You don't really get that with pre-made stringers as the top or bottom may be too high/low. And yes, you should use joist hangers, that's usually code in most places.
https://www.amazon.com/Advanced-Stair-Stringer-Layout-Methods-ebook/dp/B007URAYO8
Oh and as for trip hazards, I know one landlord that lost a case when a tenant fell on the steps. Said it cost him 60k, 30k for the tenant and 30k for the lawyer. Automatic loss for him as he had uneven steps. Code here is that you're not supposed to have more than 3/8 inch variation in step height. If you measure the whole distance and divide it out, they should all be uniform in height. There's a reason why if you go to a commercial/government building, every step you encounter will be uniform in height. (if not, trip and sue... laugh )
