Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
VOA - HCF-2, Eneos Import CVT Model H, Eneos ECO CVT
by Stucker21trt. 06/26/19 06:48 PM
2012 Mazda3 iTouring
by Kira. 06/26/19 06:46 PM
Blazer Chalet
by dishdude. 06/26/19 06:27 PM
So confused about Hemi oil
by TN Tracker. 06/26/19 06:20 PM
Gabby Chaves’ mobile oil change business
by Pat in Speedway. 06/26/19 06:03 PM
PUP 5w-30 - 2016 GS F - 5,051 miles
by Tiir. 06/26/19 05:41 PM
I-CAR Gold Class Car Wash...
by Vern_in_IL. 06/26/19 05:36 PM
Kia manual allows 5w20 and 5w30 but not 0w20?
by Whammo. 06/26/19 05:31 PM
Buy A Car...Get Freebies
by GrtArtiste. 06/26/19 05:09 PM
by Stucker21trt. 06/26/19 04:31 PM
Radar Dimax AS-8 Diamond in rough
by spiderbypass. 06/26/19 04:06 PM
icy hot additive for oils
by 1978elcamino. 06/26/19 03:33 PM
Why does diesel stink so much less than gas?
by atikovi. 06/26/19 02:29 PM
Mackay radiator hoses?
by atikovi. 06/26/19 02:21 PM
1962 Cub Cadet Original
by Phishin. 06/26/19 01:27 PM
2008 Yamaha VX 1100 oil filter choice
by ledslinger. 06/26/19 01:09 PM
GM's HD Truck Line $100k
by earthbound. 06/26/19 12:17 PM
Huge shark York Beach Maine
by LeakySeals. 06/26/19 12:05 PM
Bungalowbill, jefferylhenry, dead_bird, mikem350, Cameldoctor
68500 Registered Users
94 registered members (928, 53' Stude, Aero540T, 9050lx, 2015_PSD, ad244, 5 invisible), 2,093 guests, and 28 spiders.
Topics291,010
Posts4,996,944
Members68,500
Most Online2,967
Mar 10th, 2019
2008 Subaru Legacy Vibration at wits end! #4785543
06/13/18 07:23 AM
06/13/18 07:23 AM
Ocala, Florida
racin4ds Offline OP
racin4ds  Offline OP
Ocala, Florida
Hi guys, I'm looking for some advice. I consider myself a pretty decent mechanic, been turning wrenches for around 20 years and have many certs to go with it but I don't do it as a trade anymore.
Anyway, my wife's 2008 Legacy GT has had a vibration or "shimmy" that has been there since we acquired the car. I thought new tires and good balance would fix it but I was wrong. It occurs exactly at 62-65mph and seems to come and go... I've rotated the tires, checked for bent wheels etc. I've went up with air pressure and down. I've checked for wheel bearing play and tie rod play. Nothing in the front end seems loose. I'm convinced it is NOT the wheel/tire as it is still occurs exactly the same speed no matter which tire it where and done it with the old tires.
The only fault thats visible that I haven't addressed yet is a torn CV boot on the passenger side. I have a new axle and plan to do that this weekend.
Brakes and rotors were replaced with new powerslot kit about 10k miles ago. I'm getting ready to just rip the entire front end apart and replace everything but I'd like to avoid that if necessary...
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785557
06/13/18 07:38 AM
06/13/18 07:38 AM
Apple Valley, California
Chris142 Offline
Chris142  Offline
Bent or worn axle
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: 2008 Subaru Legacy Vibration at wits end! [Re: Chris142] #4785563
06/13/18 07:44 AM
06/13/18 07:44 AM
Ocala, Florida
racin4ds Offline OP
racin4ds  Offline OP
Ocala, Florida
But in my years of experience, a bad CV axle usually only rears its head on hard acceleration or sharp turns, neither of which mine does.
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785576
06/13/18 07:59 AM
06/13/18 07:59 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Inner CV joint problems can cause this on some Subaru, the boot looks perfect but the grease has turned to oil and the joint worn out. Did you check for rack play, internal movement and the mounting bushings?
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785589
06/13/18 08:15 AM
06/13/18 08:15 AM
Missouri
Oily_Thing Offline
Oily_Thing  Offline
Missouri
Bad engine mount.
2013 Cadillac XTS4 3.6
2015 Dodge Durango Limited 3.6
2011 Kawasaki Vulcan Voyager 1700
Re: 2008 Subaru Legacy Vibration at wits end! [Re: Oily_Thing] #4785603
06/13/18 08:27 AM
06/13/18 08:27 AM
wv
krismoriah72 Offline
wv
Could be a few things..im a subaru guy..or was.
If its an aftermarket CV shaft there were issues with them not being balanced properly that was yrs ago.
Sticky or frozen caliper/piston
Bad hub or wheel bearing
Ball Joints
Bent Rim
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785612
06/13/18 08:36 AM
06/13/18 08:36 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
I would listen to the 2 answers from the seasoned mechanics - and they point to an axle related issue.
Chris142 and Trav
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785750
06/13/18 10:46 AM
06/13/18 10:46 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
This problem has been on going since the car was new and the Stealership never fixed it? I guess that's just one more reason not to buy a Subaru they ignore to many warranty issues.
2004 Corolla 132907
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 75007
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2008 Subaru Legacy Vibration at wits end! [Re: JohnnyJohnson] #4785807
06/13/18 11:43 AM
06/13/18 11:43 AM
The land of USA-made Subies!
SubieRubyRoo Offline
Johnny, way to jump off the cliff without reading the details... he said it was present "since we acquired the car". Nothing mentioned at all about buying it new. And Subaru obviously isn't as horrible as you make them out to be, they've been awarded the vehicles with highest resale value like 3 times out of the past 5 years... people aren't willing to pay top dollar for used pieces of junk. Not like a new Dodge minivan, which loses something stupid like 83% of its value in the first 5 years...
OP, I had the same issue on my Odyssey two years ago, which showed up when I had snow tires on. At first, I thought it was the tires, so I rotated and rebalanced them to no avail. I called my brother who is also a mechanic, and said essentially the same thing as Trav; inner CVs. I checked and none of the boots were torn, but the vibration was getting pretty bad. I had both axles replaced, and voila, no more vibration at any speed.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: SubieRubyRoo] #4785832
06/13/18 12:12 PM
06/13/18 12:12 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Looks like car was purchased 1/15/17:
Originally Posted By: racin4ds
Hi All,
Just picked up a nice little 08 Subaru Legacy GT 2.5 Turbocharged. Very nice little ride! I have no previous experience with a turbocharged gasoline car. It calls for 5W30 but I'm wondering since it is likely to abuse the oil more than a standard engine if I shouldn't run a 5W40 or 0W40 syn? In the diesel world most cars/trucks are running a 40W I guess due to viscosity breakdown from the extra heat.
Looking for thoughts and opinions from others with small, turbocharged vehicles. I could care less about CAFE/MPG. I want PROTECTION!
Also Subaru experts, anything I should be on the lookout for? Are these things reliable?
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785851
06/13/18 12:34 PM
06/13/18 12:34 PM
Charlotte, NC
Oldmoparguy1 Offline
Charlotte, NC
I had a similar issue on my 2000 Dodge GC some years ago. Was the original axle with 120k on the van. It looked fine. Finally, the boot cracked and it started slinging grease. Replaced with a new shaft and there was no more weird stuff. In my case it was the right shaft.
YMMV
Wayne
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785984
06/13/18 03:36 PM
06/13/18 03:36 PM
Ocala, Florida
racin4ds Offline OP
racin4ds  Offline OP
Ocala, Florida
Yes car was purchased used- not new so no dealers involved.
I'm going after the axles this weekend so we'll see what that brings, thanks for the tips/advice gents!!
Overall, I love the car, it has 150k on the clock now and nothing has been done other than the turbo replacement when I bought it. (why I got it so cheap) It handles great, runs very well and is a blast to drive with the 5 speed.
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4786005
06/13/18 04:04 PM
06/13/18 04:04 PM
Trav Offline
Trav  Offline
I have 3 of those OE axles sitting right in the garage waiting for new inner joints (outer are perfect just reboot job with poly) I ordered from Europe. Every one of them a lube fail on the inner, perfect boots.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: Trav] #4786347
06/14/18 01:41 AM
06/14/18 01:41 AM
Northeast
sxg6 Offline
sxg6  Offline
Northeast
Just a heads up.. If it's an AT legacy, I've heard that people have vibrations at idle with aftermarket cv axles. I understand that's not your current issue, but if you're putting an aftermarket in this weekend, that could happen. The vibration occurs when stopped in drive, but goes away if you shift into neutral.
Not sure what the culprit might be for your current vibration issue.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4786402
06/14/18 05:37 AM
06/14/18 05:37 AM
NYC, NY
ccs368 Offline
ccs368  Offline
NYC, NY
I replaced both left and right side torn inner boots with Dorman universal silicone CV boots as they claim silicone is more heat resilient to poly boots. So far it has not torn after 1 year or 12K miles. It was for a 06 Outback with 95K at the time. The reason for boot replacement and not entire axle replacement was for the reasons posters mentioned above with aftermarket axles creating vibration or fitment issues plus cost. Allwheeldriveauto.com has an excellent write up just for this repair. Also, two well respected youtubers, south main auto and pine hollow diagnostics have videos depicting using OEM and not aftermarket axle replacements too. I followed pine hollow diagnostics video to separate the joint but keeping the green cup coupled to the transmission case. Maybe investigate if your axles were replacements with aftermarket too before you purchased car and systematically eliminate potential causes of your vibration issues.
2015 Toyota Sienna LE FWD 0w20
2003 Toyota Corolla LE 5w30
2006 Suzuki Vinson LT-F500F 10w40
2004 Harley-Davidson Fatboy FLSTF 20w50
2001 Ducati 996S 20w50
