Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
Oil weight and FM
by Brian553. 01/22/19 01:07 PM
New Bridgestone Blizzak WS90
by SubLGT. 01/22/19 12:59 PM
Southwest Airlines slides off runway
by JustN89. 01/22/19 12:55 PM
phenolic caliper pistons
by bionictony. 01/22/19 12:31 PM
SS snowblower auger to scraper gap?
by dwcopple. 01/22/19 11:47 AM
PP HM 10W-30 at Walmart for $15
by 28oz. 01/22/19 11:30 AM
2012 Camry ATF change- now or later?
by TmanP. 01/22/19 11:20 AM
Oil sampling tube
by kevmor99. 01/22/19 10:00 AM
Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
112 registered members (alarmguy, 2015_PSD, 28oz, AdditiveOCD, 6 invisible), 2,282 guests, and 38 spiders.
Topics296,986
Posts4,963,009
Members67,013
Most Online2,821
Jan 21st, 2019
Oil question for a 2018 6.7 Powerstroke #4785704
06/13/18 09:05 AM
06/13/18 09:05 AM
Wisconsin
Dfinkler Offline OP
Dfinkler  Offline OP
Wisconsin
My mechanic is telling that he wants me to use schaeffer 15w/40. What do you recommend for a 2018 F250 Powerstroke? I live in southern Wisconsin.
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785709
06/13/18 09:09 AM
06/13/18 09:09 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Yah I'll bet he does what's he going to charge you for it?
2004 Corolla 128335
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785720
06/13/18 09:17 AM
06/13/18 09:17 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Schaefers is good oil. Mail order it and carry it in. See what he says when you supply the oil laugh
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785727
06/13/18 09:21 AM
06/13/18 09:21 AM
Texas
Cedarshark Offline
Cedarshark  Offline
Texas
Difficult to answer unless you provide more info. We know you need cold starting capability. How much do you drive and tow?
F-250 PS
HOnda CRV
FOrd 1710 Diesel Tractor
30 chainsaws
Kawasaki mule
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785785
06/13/18 10:26 AM
06/13/18 10:26 AM
PA
umungus1122 Offline
umungus1122  Offline
PA
What does it spec? Do you have an auxiliary oil cooler? How much do you tow?
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785789
06/13/18 10:28 AM
06/13/18 10:28 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
I would run a 5W40 synthetic that is Ford approved. You will need to check the Ford document on oils approved for the Ford Powerstroke (this is all about CK-4 oil).
Rotella T6 5W40 in the containers that pass the Ford spec would good.
Delo 5W40 is also good. I see a lot of that oil that is CJ-4 on shelves at Walmart. Stock up on some of that. The CJ-4 passes the Ford spec. But if its CK-4 then you need to check to see if it passes the Ford spec.
2015 Ford F250 w/Powerstroke
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785814
06/13/18 10:48 AM
06/13/18 10:48 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Yes, make sure it has the Ford spec WSS-M2C171-F1, a lot of CK-4 oils do not meet the Ford spec.
Given you are in Wisconsin, I would look at a 5W-40 weight.
https://www.fcsdchemicalsandlubricants.c...20Statement.pdf
https://www.fcsdchemicalsandlubricants.com/main/additionalinfo/dieseloilsWSSM2C171F1.pdf
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785875
06/13/18 11:56 AM
06/13/18 11:56 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Read the owners manual and use an oil with the specs recommended by Ford.Buy an oil from any of the major companies.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785959
06/13/18 01:58 PM
06/13/18 01:58 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
You really don't need your mechanic to change your oil.
That said I just got out from under my SUV now and changed it so I
understand.......
Ford gives big deal coupons on new trucks and you couldn't even buy the oil for what they do it for. They used to take 13.5 quarts. Don't know what your new one takes.
But an oil change from an independent could be really expensive.
"If I walked on water, they'd say I couldn't swim."
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4785987
06/13/18 02:41 PM
06/13/18 02:41 PM
Reno, Nevada
Langanobob Online content
Langanobob  Online Content
Reno, Nevada
I suggest asking Schaeffers and getting their recommendation. We need to be kind to Schaeffers around here, the Bob (RIP) in Bobistheoilguy was a Schaeffers rep.
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4786043
06/13/18 03:56 PM
06/13/18 03:56 PM
Michigan
Buzzinhalfdozen Offline
Michigan
Unless you use the truck for towing and by towing I mean more than on the weekends you don't need a 15w-40 or 5w-40. If you look at previous threads there are plenty of powerstrokes running a 10w-30. 10w-30 as far as I know is factory fill. I've read alot of threads where 5w-40 shears down to a 30 anyway while the 10w-30 stays in grade. No need for expensive synthetics if you're going to change oil according to the owners manual and not push gvwr.
My dad just picked up a new 2018 F-250 I put Rotella T5 10w-30 in it for him at 4400 miles. He tows 15k on the weekends. Will be keeping a UOA record on this truck as well. By the way there are quite a few c&p of filters as well, take a look. I know the baldwin b7379 filter is wire backed synthetic as that's what I put on.
1999 Jeep Cherokee sport 4.0L
2015 Jeep Cherokee 3.2L
Re: Oil question for a 2018 6.7 Powerstroke [Re: Buzzinhalfdozen] #4786072
06/13/18 04:31 PM
06/13/18 04:31 PM
Zee09 Offline
Zee09  Offline
Did he wait the 1000 miles before he towed?
That was tough on me, the wait smile
Re: Oil question for a 2018 6.7 Powerstroke [Re: Zee09] #4786182
06/13/18 06:46 PM
06/13/18 06:46 PM
Michigan
Michigan
Yes he did, I think a vacation was taken shortly after purchase and that was about 1500 miles.
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4786452
06/14/18 06:33 AM
06/14/18 06:33 AM
Idaho
BoiseRob Offline
BoiseRob  Offline
Idaho
Schaeffer's Supreme 9000 series is still CJ4. My Jeep GC Ecodiesel uses the S-9000 5w40 and my LBZ Duramax uses the S-9012 10w30. Great oil at a reasonable price...
FYI... The Duramax pulls our 10K# TT throughout the Idaho Rockies..
Re: Oil question for a 2018 6.7 Powerstroke [Re: Dfinkler] #4786553
06/14/18 08:43 AM
06/14/18 08:43 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
2016 PSD owner here.
Schaeffer is a fine oil no doubt. So is Valvoline Premium Blue and Rotella. All of those vendors 10w30 are on the list.
I'm in the camp of a 10 w being good to 20 degrees F, so if you get colder than that in Wisconsin, consider a 5w40. Your truck going to a cold climate may have come with a block heater. If so, I would stick with the 10w30 year round. Seriously, you'll find the 6.7 will start and run in any temperature you are brave enough to walk out into unassisted anyway.
I'm running Delo 15w30 in mine, but it gets stored along with the camper from October through March, so no cold starts for me.
beanoil: Tough under heat, real dirty afterwards.
