SKF grease with graphite
by PreludeDenarius. 05/24/19 03:42 AM
Quaker State Ultimate Durability 5W-30: $17.97 at WM
by The Critic. 05/24/19 01:31 AM
AT-205 Re-Seal for 1968 VW Bus?
by ZraHamilton. 05/24/19 01:22 AM
Can 5W-30 be Thicker than 10W-30?
by John344. 05/23/19 10:33 PM
Fastenal new policy-unhappy
by rekit. 05/23/19 10:23 PM
0w30 Showdown of European Oils
by Marco620. 05/23/19 10:12 PM
amazon basics 5-40 not as good
by benjy. 05/23/19 09:28 PM
Cost to Repair a Honda V6 Engine that Jumps Time
by The Critic. 05/23/19 09:18 PM
Youtube demonitisation of conspiracy sites ?
by Shannow. 05/23/19 09:15 PM
03 Subaru WRX Valvoline VR1 10/30 196K miles
by TurboJW. 05/23/19 08:43 PM
TT time
by benjy. 05/23/19 08:29 PM
Castrol Nexcel
by JunkdrawerDog. 05/23/19 08:25 PM
1st gen ford focus
by WhyMe. 05/23/19 08:21 PM
Coca-Cola 600
by kstanf150. 05/23/19 07:49 PM
New cell phones and company
by spk2000. 05/23/19 07:24 PM
Swivel Elbow for Garden hose reel
by JC1. 05/23/19 06:57 PM
Garage floor coating
by Eddie. 05/23/19 06:43 PM
Tina70, tongboy1, PersonaPriusDad, MetricMike, Harps
68195 Registered Users
27 registered members (4WD, CB900F2, 2015_PSD, carviewsonic, Bjornviken, 08z06, 4 invisible), 612 guests, and 23 spiders.
Topics289,326
Posts4,967,017
Members68,195
Most Online2,967
Mar 10th, 2019
Oil change #4785648
06/13/18 09:03 AM
06/13/18 09:03 AM
NY
mx5miata Offline OP
mx5miata  Offline OP
NY
So mad at myself that I did not change out crush washer. duh horse
Got an extra 1/3 of a turn on drain plug
Hopefully the slightest trickle stops.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Oil change [Re: mx5miata] #4785653
06/13/18 09:08 AM
06/13/18 09:08 AM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
If it drips you can always drain it into a clean container and put it back in.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: Oil change [Re: rollinpete] #4785657
06/13/18 09:12 AM
06/13/18 09:12 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Just use a shop vac and drain nothing, remove bolt, change washer and put it back in.
Re: Oil change [Re: mx5miata] #4785660
06/13/18 09:16 AM
06/13/18 09:16 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
I used the same crush washer that came from the factory for 14 years on my Subaru and it never leaked a drop. It's not the end of the world.
Re: Oil change [Re: mx5miata] #4785671
06/13/18 09:27 AM
06/13/18 09:27 AM
WA
OilUzer Offline
OilUzer  Offline
WA
Just curious, how can you tell you "got an extra 1/3 of a turn"?
I have reused many times when the washer looked perfect (like new) but I typically like to use a new one. You should be fine. Check for leak a few times ...
Edit:
Nevermind, looks like you have a leak?!
Re: Oil change [Re: Trav] #4785672
06/13/18 09:29 AM
06/13/18 09:29 AM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Did you see his socket wrench?
"If I walked on water, they'd say I couldn't swim."
Re: Oil change [Re: mx5miata] #4785684
06/13/18 09:41 AM
06/13/18 09:41 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I change the flat washer after 3-4 uses but, always change a a crush washer every time.
2014 CX5 Touring 2.5L :-)
Re: Oil change [Re: mx5miata] #4785695
06/13/18 09:52 AM
06/13/18 09:52 AM
sonoma
burla Offline
burla  Offline
sonoma
help prevent the pot holes out there, but also causes problems for drivers in the rain.
Re: Oil change [Re: mx5miata] #4785710
06/13/18 10:10 AM
06/13/18 10:10 AM
McGregor TX
mrdctaylor Offline
mrdctaylor  Offline
McGregor TX
Another reason I've used a Fumoto valve on my truck. I haven't had to remove/reinstall a drain plug or crush washer on it in 16 years. grin
Seriously though, 80% of my reason for using a Fumoto valve is convenience. 20% is to keep from accidentally cross-threading or stripping the oil pan. I know chances are small if you're careful, but it happens.
02 Tacoma 3.4L, 225K, Magnatec 10W30
12 Highlander 3.5L, 104K, Napa Syn 0W20
17 Escape 2.0L, 37K, Hav ProDS 5W30
02 Trailblazer 4.2L, 186K, Edge HM 10W40
Re: Oil change [Re: Zee09] #4785822
06/13/18 11:59 AM
06/13/18 11:59 AM
Trav Offline
Trav  Offline
Yep an old school bone wrench. I don't like them but some guys use them for oil changes, they work.
Re: Oil change [Re: OilUzer] #4785914
06/13/18 01:38 PM
06/13/18 01:38 PM
NY
mx5miata Offline OP
mx5miata  Offline OP
NY
I normally use a 5/16 hex, used an 8mm and was able to get better torque and the bolt tightened up a bit more didn't move much less than a 1/4 turn
Wix air filter
Re: Oil change [Re: Trav] #4786304
06/13/18 10:44 PM
06/13/18 10:44 PM
WA
OilUzer Offline
OilUzer  Offline
WA
That's a very neat trick! I would have never thought of that thinking it may suck the oil out and ruin my vac ... lol
Mx5miata,
Did how did u fix the problem?
Re: Oil change [Re: Trav] #4786321
06/13/18 11:26 PM
06/13/18 11:26 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
Impressive! That is creativity at it's finest.
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: Oil change [Re: mx5miata] #4786470
06/14/18 08:06 AM
06/14/18 08:06 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Subie had NH plates. Neat trick and the motor on my 20yr old Rigid could use some lube. grin2
Thick oil is better grin2
Re: Oil change [Re: mx5miata] #4787012
06/14/18 08:18 PM
06/14/18 08:18 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Shop vac is good stuff
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
