Is it time for a brake fluid flush?
by A_A_G - 09/21/19 03:22 AM
Take that!
by Mad_Hatter - 09/21/19 03:18 AM
02 Honda Accord V6 Aluminum Radiator
by David1 - 09/21/19 01:55 AM
Difinitive Answer for SCA, Silicates, and Diesels
by ErikLeifson - 09/20/19 11:11 PM
Quart bottle cap
by maverickfhs - 09/20/19 11:11 PM
Dexron vi
by charmer37 - 09/20/19 10:22 PM
Deposit Shield
by TheLawnRanger - 09/20/19 10:00 PM
Atlanta Airport - Excellent History
by ctechbob - 09/20/19 09:56 PM
Angry at Walmart service center
by Jetsfan421 - 09/20/19 09:52 PM
Fuel System Cleaners
by ZeeOSix - 09/20/19 09:22 PM
Milwaukee 1/2 impact
by wensteph - 09/20/19 09:10 PM
Windows 7 Use After Support Ends
by ZeeOSix - 09/20/19 08:29 PM
Walmart Poulan chainsaws 50% off
by bubbatime - 09/20/19 08:10 PM
Vintage "Ultra Lube" Grease (show & tell)
by GaryPoe - 09/20/19 08:09 PM
Impact driver for auto work?
by Klutch9 - 09/20/19 07:27 PM
2000 Honda CR-V Ex transmission fluid?
by taztheman - 09/20/19 05:36 PM
Pennzoil Launches Four New Motor Oils
by jayjr1105 - 09/20/19 05:25 PM
Strange TPMS ID and no tire warning yet
by Patrick0525 - 09/20/19 05:18 PM
HF Icon Tool Storage - A Game Changer?
by user52165 - 09/20/19 04:39 PM
Update on my sister's oil burning Tucson
by carviewsonic - 09/20/19 04:37 PM
TungGT, ErikLeifson, Kinnes25, Bamajoe, Aleksandar
69347 Registered Users
40 registered members (2015_PSD, berlyn, 87sammy, 4WD, bbhero, 6 invisible), 796 guests, and 32 spiders.
Topics294,847
Posts5,067,846
Members69,347
Most Online3,532
Jul 30th, 2019
2008 Subaru Legacy Vibration at wits end! #4785543 06/13/18 07:23 AM
R
racin4ds Offline OP
R
Hi guys, I'm looking for some advice. I consider myself a pretty decent mechanic, been turning wrenches for around 20 years and have many certs to go with it but I don't do it as a trade anymore.
Anyway, my wife's 2008 Legacy GT has had a vibration or "shimmy" that has been there since we acquired the car. I thought new tires and good balance would fix it but I was wrong. It occurs exactly at 62-65mph and seems to come and go... I've rotated the tires, checked for bent wheels etc. I've went up with air pressure and down. I've checked for wheel bearing play and tie rod play. Nothing in the front end seems loose. I'm convinced it is NOT the wheel/tire as it is still occurs exactly the same speed no matter which tire it where and done it with the old tires.
The only fault thats visible that I haven't addressed yet is a torn CV boot on the passenger side. I have a new axle and plan to do that this weekend.
Brakes and rotors were replaced with new powerslot kit about 10k miles ago. I'm getting ready to just rip the entire front end apart and replace everything but I'd like to avoid that if necessary...
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785557 06/13/18 07:38 AM
Chris142 Offline
Bent or worn axle
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2008 Subaru Legacy Vibration at wits end! [Re: Chris142] #4785563 06/13/18 07:44 AM
R
racin4ds Offline OP
R
But in my years of experience, a bad CV axle usually only rears its head on hard acceleration or sharp turns, neither of which mine does.
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785576 06/13/18 07:59 AM
T
Trav Offline
T
Inner CV joint problems can cause this on some Subaru, the boot looks perfect but the grease has turned to oil and the joint worn out. Did you check for rack play, internal movement and the mounting bushings?
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785589 06/13/18 08:15 AM
O
Oily_Thing Offline
O
Bad engine mount.
2013 Cadillac XTS4 3.6
2015 Dodge Durango Limited 3.6
Re: 2008 Subaru Legacy Vibration at wits end! [Re: Oily_Thing] #4785603 06/13/18 08:27 AM
K
krismoriah72 Online Content
Online Content
K
Could be a few things..im a subaru guy..or was.
If its an aftermarket CV shaft there were issues with them not being balanced properly that was yrs ago.
Sticky or frozen caliper/piston
Bad hub or wheel bearing
Ball Joints
Bent Rim
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785612 06/13/18 08:36 AM
Danno Offline
I would listen to the 2 answers from the seasoned mechanics - and they point to an axle related issue.
Chris142 and Trav
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785750 06/13/18 10:46 AM
JohnnyJohnson Offline
This problem has been on going since the car was new and the Stealership never fixed it? I guess that's just one more reason not to buy a Subaru they ignore to many warranty issues.
2004 Corolla 135530
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76414
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2008 Subaru Legacy Vibration at wits end! [Re: JohnnyJohnson] #4785807 06/13/18 11:43 AM
SubieRubyRoo Offline
Johnny, way to jump off the cliff without reading the details... he said it was present "since we acquired the car". Nothing mentioned at all about buying it new. And Subaru obviously isn't as horrible as you make them out to be, they've been awarded the vehicles with highest resale value like 3 times out of the past 5 years... people aren't willing to pay top dollar for used pieces of junk. Not like a new Dodge minivan, which loses something stupid like 83% of its value in the first 5 years...
OP, I had the same issue on my Odyssey two years ago, which showed up when I had snow tires on. At first, I thought it was the tires, so I rotated and rebalanced them to no avail. I called my brother who is also a mechanic, and said essentially the same thing as Trav; inner CVs. I checked and none of the boots were torn, but the vibration was getting pretty bad. I had both axles replaced, and voila, no more vibration at any speed.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: SubieRubyRoo] #4785832 06/13/18 12:12 PM
SatinSilver Offline
Looks like car was purchased 1/15/17:
Originally Posted By: racin4ds
Hi All,
Just picked up a nice little 08 Subaru Legacy GT 2.5 Turbocharged. Very nice little ride! I have no previous experience with a turbocharged gasoline car. It calls for 5W30 but I'm wondering since it is likely to abuse the oil more than a standard engine if I shouldn't run a 5W40 or 0W40 syn? In the diesel world most cars/trucks are running a 40W I guess due to viscosity breakdown from the extra heat.
Looking for thoughts and opinions from others with small, turbocharged vehicles. I could care less about CAFE/MPG. I want PROTECTION!
Also Subaru experts, anything I should be on the lookout for? Are these things reliable?
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785851 06/13/18 12:34 PM
O
Oldmoparguy1 Offline
O
I had a similar issue on my 2000 Dodge GC some years ago. Was the original axle with 120k on the van. It looked fine. Finally, the boot cracked and it started slinging grease. Replaced with a new shaft and there was no more weird stuff. In my case it was the right shaft.
YMMV
Wayne
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4785984 06/13/18 03:36 PM
R
racin4ds Offline OP
R
Yes car was purchased used- not new so no dealers involved.
I'm going after the axles this weekend so we'll see what that brings, thanks for the tips/advice gents!!
Overall, I love the car, it has 150k on the clock now and nothing has been done other than the turbo replacement when I bought it. (why I got it so cheap) It handles great, runs very well and is a blast to drive with the 5 speed.
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4786005 06/13/18 04:04 PM
T
Trav Offline
T
I have 3 of those OE axles sitting right in the garage waiting for new inner joints (outer are perfect just reboot job with poly) I ordered from Europe. Every one of them a lube fail on the inner, perfect boots.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: Trav] #4786347 06/14/18 01:41 AM
sxg6 Offline
Just a heads up.. If it's an AT legacy, I've heard that people have vibrations at idle with aftermarket cv axles. I understand that's not your current issue, but if you're putting an aftermarket in this weekend, that could happen. The vibration occurs when stopped in drive, but goes away if you shift into neutral.
Not sure what the culprit might be for your current vibration issue.
Re: 2008 Subaru Legacy Vibration at wits end! [Re: racin4ds] #4786402 06/14/18 05:37 AM
ccs368 Offline
I replaced both left and right side torn inner boots with Dorman universal silicone CV boots as they claim silicone is more heat resilient to poly boots. So far it has not torn after 1 year or 12K miles. It was for a 06 Outback with 95K at the time. The reason for boot replacement and not entire axle replacement was for the reasons posters mentioned above with aftermarket axles creating vibration or fitment issues plus cost. Allwheeldriveauto.com has an excellent write up just for this repair. Also, two well respected youtubers, south main auto and pine hollow diagnostics have videos depicting using OEM and not aftermarket axle replacements too. I followed pine hollow diagnostics video to separate the joint but keeping the green cup coupled to the transmission case. Maybe investigate if your axles were replacements with aftermarket too before you purchased car and systematically eliminate potential causes of your vibration issues.
2015 Toyota Sienna LE FWD 0w20
2003 Toyota Corolla LE 5w30
2006 Suzuki Vinson LT-F500F 10w40
2004 Harley-Davidson Fatboy FLSTF 20w50
2001 Ducati 996S 20w50
