Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
91 registered members (86cutlass307, ABN_CBT_ENGR, 4WD, 77GrandPrix, 2015_PSD, 55hambone, 6 invisible), 2,555 guests, and 47 spiders.
Topics306,067
Posts5,286,760
Members71,593
You're supposed to change a diesel filter??!!?? #4785370 06/12/18 10:59 PM
bdcardinal Offline OP
A customer came in on Saturday and brought this filter in. This is the engine mounted fuel filter on a Ford 6.0L Powerstroke, there is one mounted on the frame, as the picture of new filters shows. He said he just wanted the o-ring for the housing since it was leaking and he put RTV around it a few years ago and that started to leak. Now the book says to change them both every 15K miles, you have to buy them as a set. Most owners do them a lot more frequently to try and extend injector life. I told the customer that we don't stock the o-ring by itself, I could order it but it wouldn't be in until Tuesday. However we stock the filter set and I am guessing by him saying he RTV'd the cap a few years ago and since the frame mounted one will get that discolored if you extend the interval, he should do them. He balked and said it was too expensive but I ended up selling the filter set to him at wholesale cost. He then got upset that he had to get both.
After he left I realized what a terrible thing I had done. That 2004 F-250 probably had the factory filters still in it and was probably one of the only 2004 6.0s to never have any work done beyond oil changes every Presidential Inauguration. I kept it until Monday to show our diesel tech who about fainted seeing it.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785405 06/13/18 12:14 AM
Nick1994 Offline
Looks like a diesel oil filter crzy
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785417 06/13/18 12:40 AM
SubieRubyRoo Offline
Heml Be back shortly for injectors and other work, at least to a shop, maybe not yours, since he will wrongly blame your shop for causing the breakdowns that are surely coming in short order.
De omnibus dubitandum.
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785421 06/13/18 01:22 AM
Silk Offline
You often see a bit of black in a common rail fuel filter, oil getting into the return line. It was an indication of a fuel pump problem with the Mitsubishi 4M40...the lift pump is in the front of the injector pump, and they would suck engine oil. On a hard start complaint, checking the fuel filter was the first thing to do. We have one at work at the moment...I had trouble starting it, and it stalled a couple of times. In the morning we will drop the fuel filter for a look.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785424 06/13/18 02:07 AM
F
Falcon_LS Offline
F
RTV eh? Sounds like ones of those folks who shouldn't be allowed anywhere near a vehicle, it never seizes to amaze me.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785430 06/13/18 02:32 AM
02SE Offline
The maintenance neglect from some vehicle owners never ceases to amaze me.
I've been meaning to ask: Have you seen any CP4.2 HPFP failures come through your shop?
Re: You're supposed to change a diesel filter??!!?? [Re: Falcon_LS] #4785439 06/13/18 02:58 AM
M
mjoekingz28 Offline
M
Originally Posted By: Falcon_LS
seizes
"ceases" my Middle East fellow!
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785535 06/13/18 07:15 AM
R
racin4ds Offline
R
Yep and next month he'll be on a forum somewhere talking about how much a Piece of junk the 6.0 is and that it was the worst truck ever made by Ford...
I'm still convinced that a majority of the problems with the 6.0 is from pure lack of knowledge and maintenance when owning a diesel truck. They weren't meant to ride around on stretched Nitto 420's and be drag raced nor were they meant to run to the save-a-lot and lowes once a week to haul groceries.
I guess in this case, he was lucky to have always had good quality fuel, that is the ONLY way that filter lasted that long. I'd hate to see the amount of gunk built up in that frame rail HFCM!!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: You're supposed to change a diesel filter??!!?? [Re: SubieRubyRoo] #4785536 06/13/18 07:17 AM
Delta Offline
I doubt it. People like this have luck on their side it seems. If he has gone this far on a 6.0 with little to no maintenance it'll probably run forever doing the same. Funny how people complain about a less than $50 filter kit but will spend money on other vice's daily...
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785544 06/13/18 07:24 AM
Rat407 Offline
Heck, that filter was probably super efficient at not letting anything through. The fuel pump will like the increased flow I'm sure.
2002 Silverado 5.3 5w-20 AMSOIL
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785572 06/13/18 07:50 AM
T
Trav Offline
T
That looks like something from a 10 yr old house furnace. LOL
Re: You're supposed to change a diesel filter??!!?? [Re: 02SE] #4785733 06/13/18 10:27 AM
I think that is what they use on the 6.7 correct? There is actually one in the shop now. The tech brought in the actuator on top and it was covered in metal flakes. We priced out the "oops I messed up kit" which is meant for fixing when people put DEF in the fuel and run it, however it is on intergalactic backorder. The fuel injectors, pump to pipe lines, and return lines are on backorder thus putting the whole kit on backorder. Supposedly it is covered under the owner's extended warranty.
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4785740 06/13/18 10:33 AM
T
TheLawnRanger Offline
T
That filter, as bad as it is, could have been much worse. If that would have been me, the engine would have had trouble years ago.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: You're supposed to change a diesel filter??!!?? [Re: bdcardinal] #4788785 06/17/18 12:52 AM
T
Tornado Red Offline
T
It is easy enough to mount an after-market fuel filter in place of the original ones -- for instance, the Cat 1R-0750 with an easy-to-find generic filter head. Probably good for 50k or at least 40k miles in a 6-liter Ford diesel. And rated for 2 microns, instead of 15 or 20 microns in the OE filter.
'03 Golf TDI, 801k miles: Bosio DLC764, GT1749VB, Malone Tuning, G60/VR6 clutch/flywheel, Bilstein HD, Recaros, Akebonos, Brembos, Pirellis, DG Panzer & FMJ, Delvac 1 5W40
