Does Super Lube Oil make Good Electric Motor Oil
by vortex - 08/24/19 04:40 PM
26 degree temp swing in 24 hours
by gman2304 - 08/24/19 04:12 PM
FEDERATED PG4459F CUT OPEN
by 53' Stude - 08/24/19 03:58 PM
Reverse mortgage questions.
by callbay - 08/24/19 03:45 PM
Moly vs No Moly
by Navi - 08/24/19 03:08 PM
M1 5W30 SN+ D1/G2 VOA ?
by ChrisD46 - 08/24/19 03:04 PM
Castrol 0w40 no longer LL-01 ?
by Ndx - 08/24/19 02:32 PM
Different TGMO bottles?
by gwiffer - 08/24/19 02:07 PM
Oil change before car sitting 1 year?
by clarkflower - 08/24/19 12:47 PM
Havoline Smart Change on RB
by Mad_Hatter - 08/24/19 11:54 AM
TFL Truck testing Rotella Gas Truck.
by A_Harman - 08/24/19 11:34 AM
01 Nissan Sentra 2.0 AC issue
by Mark72 - 08/24/19 11:21 AM
I should have bought that Daewoo
by 5AcresAndAFool - 08/24/19 10:24 AM
Correct Temps to Check ATF Fill
by Gebo - 08/24/19 09:48 AM
Subie5w30, Iautox, Mayadi, YachtRocket, WoodworkerII
69054 Registered Users
98 registered members (92saturnsl2, 4WD, 25ring, 2002 Maxima SE, 01rangerxl, 9 invisible), 2,379 guests, and 24 spiders.
Topics293,740
Posts5,045,934
Members69,053
Most Online3,532
Jul 30th, 2019
2017 WRX STI: Motul X-clean EFE - 5,000 miles #4784224 06/11/18 07:16 PM
T
Tiir Offline OP
T
Motul X-clean 5w-30 EFE fill.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784236 06/11/18 07:28 PM
O
oil_film_movies Offline
O
Copper is probably from the oil cooler. Its been seen a lot on WRX engines. The other possible source is the crank bearings, yet it just seems unlikely here.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784565 06/12/18 06:58 AM
Snagglefoot Online Content
Online Content
For what itís worth that is a very low iron number, down at 1 ppm/ 1000 miles. Where the other checks with the same Motul oil?
If you want the job done right......do it yourself.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784694 06/12/18 09:18 AM
G
Gubkin Offline
G
"TBN is still good at 2.2. Try 7000 miles"
Crazy lab! )))))))
It's mean that TBN > TAN
necessary decrease interval to 4000 miles
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784713 06/12/18 09:32 AM
K
kschachn Offline
K
What?
Crazy lab! )))))))
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784735 06/12/18 10:00 AM
G
Gubkin Offline
G
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784746 06/12/18 10:07 AM
Z
zeng Offline
Z
Very good metal wear rates.
Cu and (part of) Al likely comes from cooler, not bearing.
This C3 oil of TBN 7.8 drops to 2.2 over 5100 miles, which I interprete as good TBN retention.
I won't look at TAN , if any, and agree with BStone OCI could be extended further to 7000 miles or probably beyond.
Edit:The test of the pudding is in the eating, which in this case refers to (the very good) Fe wear of 5 ppm over 5100 miles.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784786 06/12/18 11:10 AM
B
bluesubie Offline
B
I believe that Blackstone uses a different ASTM test than either of those (at least they used to).
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=221275
I doubt the OP will extend the interval very much. And probably not likely to go beyond 6k miles which is Subaru of America's recommendation unless Blackstone will cover the Powertrain Warranty. smile2
'04 Subaru Forester 2.5XT
Castrol Edge 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4784788 06/12/18 11:15 AM
1
1JZ_E46 Offline
1
Wear metals ppm is only a piece of the story. You will not see deposit formation in a UOA, which you get from low TBN or where TAN is higher than TBN.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4785143 06/12/18 06:29 PM
K
kschachn Offline
K
What is the TAN here?
1994 BMW 530i, 246K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: 1JZ_E46] #4785163 06/12/18 06:48 PM
Z
zeng Offline
Z
Deposit formation,contents of Na,Ca,Mg etc, sludge,varnish,low TBN , high TAN,residual [email protected]*C, fuel dilution % etc are merely/strictly noises.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4789145 06/17/18 12:42 PM
1
1JZ_E46 Offline
1
Respectfully disagree. What a dense statement.
