Trekka, the only car made in New Zealand.
by Silk - 02/22/20 04:18 AM
Motorcraft FL-820s Video
by iunderpressure - 02/22/20 04:13 AM
Washing coolant down a storm drain?
by jharrison - 02/22/20 12:57 AM
storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
17 registered members (bachman, Gasbuggy, dlundblad, farrarfan1, Gokhan, 3 invisible), 1,088 guests, and 20 spiders.
Topics301,771
Posts5,202,429
Members70,775
2017 WRX STI: Motul X-clean EFE - 5,000 miles #4784224 06/11/18 06:16 PM
T
Tiir Offline OP
T
Motul X-clean 5w-30 EFE fill.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784236 06/11/18 06:28 PM
O
oil_film_movies Offline
O
Copper is probably from the oil cooler. Its been seen a lot on WRX engines. The other possible source is the crank bearings, yet it just seems unlikely here.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784565 06/12/18 05:58 AM
Snagglefoot Offline
For what itís worth that is a very low iron number, down at 1 ppm/ 1000 miles. Where the other checks with the same Motul oil?
If you want the job done right......do it yourself.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784694 06/12/18 08:18 AM
G
Gubkin Offline
G
"TBN is still good at 2.2. Try 7000 miles"
Crazy lab! )))))))
It's mean that TBN > TAN
necessary decrease interval to 4000 miles
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784713 06/12/18 08:32 AM
K
kschachn Offline
K
What?
Crazy lab! )))))))
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784735 06/12/18 09:00 AM
G
Gubkin Offline
G
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784746 06/12/18 09:07 AM
Z
zeng Offline
Z
Very good metal wear rates.
Cu and (part of) Al likely comes from cooler, not bearing.
This C3 oil of TBN 7.8 drops to 2.2 over 5100 miles, which I interprete as good TBN retention.
I won't look at TAN , if any, and agree with BStone OCI could be extended further to 7000 miles or probably beyond.
Edit:The test of the pudding is in the eating, which in this case refers to (the very good) Fe wear of 5 ppm over 5100 miles.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784786 06/12/18 10:10 AM
B
bluesubie Offline
B
I believe that Blackstone uses a different ASTM test than either of those (at least they used to).
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=221275
I doubt the OP will extend the interval very much. And probably not likely to go beyond 6k miles which is Subaru of America's recommendation unless Blackstone will cover the Powertrain Warranty. smile2
'20 Subaru Outback Onyx XT | FF Idemitsu 0W-20
'04 Subaru Forester 2.5XT | Edge 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4784788 06/12/18 10:15 AM
1
1JZ_E46 Offline
1
Wear metals ppm is only a piece of the story. You will not see deposit formation in a UOA, which you get from low TBN or where TAN is higher than TBN.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4785143 06/12/18 05:29 PM
K
kschachn Offline
K
What is the TAN here?
1994 BMW 530i, 251K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: 1JZ_E46] #4785163 06/12/18 05:48 PM
Z
zeng Offline
Z
Deposit formation,contents of Na,Ca,Mg etc, sludge,varnish,low TBN , high TAN,residual [email protected]*C, fuel dilution % etc are merely/strictly noises.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4789145 06/17/18 11:42 AM
1
1JZ_E46 Offline
1
Respectfully disagree. What a dense statement.
