2008 Yamaha F350 91 Hrs OCI
by nicklx. 06/24/19 08:39 PM
Guess your never too young to work on a chevy.
by rollinpete. 06/24/19 08:13 PM
Went to Jiffy Lube
by Stelth. 06/24/19 07:37 PM
safest way to remove bug residue
by NissanMaxima. 06/24/19 07:32 PM
22000 emails
by marine65. 06/24/19 06:31 PM
oil analysis to show fuel dilution
by jfairchild327. 06/24/19 06:00 PM
Mitsu 3000GT rear engine mount is tilted...
by tomcat27. 06/24/19 05:52 PM
Engine full of Fuel. What is best to do?
by LeoStrop. 06/24/19 05:50 PM
Seeking Advice Choosing Wheel Locks
by JerryBob. 06/24/19 05:19 PM
Non-stick pan
by Alfred_B. 06/24/19 05:04 PM
Had to ELIMINATE a raccoon
by Kjmack. 06/24/19 04:52 PM
Oil Consumption 6.0L AFM Unicorn?
by tahoe_hybrid. 06/24/19 04:27 PM
PP 5W-20, 3000mi, '14 Kia Soul
by tc1446. 06/24/19 03:07 PM
Cheap powerfull filter magnet
by loneryder. 06/24/19 01:50 PM
New road tire time
by UG_Passat. 06/24/19 01:46 PM
Royal Purple 75W90 vs. Store Brand Synthetic
by WondrousBread. 06/24/19 12:50 PM
Jeep Renegade MTF Alternatives?
by Sunnyinhollister. 06/24/19 12:28 PM
Havoline 0W20 VI higher than 5w30 and 10w30?
by Whammo. 06/24/19 12:10 PM
New toy...19 Jetta GLI Autobahn
by CincyDavid. 06/24/19 12:00 PM
ml98188, 84FSP, megavoyager, thaduke2003, Vitaliy
68474 Registered Users
127 registered members (2010Civic, 77GrandPrix, ABomb369, 97K15004WD, 53' Stude, 12 invisible), 2,176 guests, and 30 spiders.
Topics290,916
Posts4,995,239
Members68,474
Most Online2,967
Mar 10th, 2019
Lucas Marine Grease Formula Change #4748115
05/04/18 10:29 PM
05/04/18 10:29 PM
USA
racerdude321 Offline OP
USA
Hi All,
Great forum, I've lurked for awhile but just now joined up.
I've been using Lucas Marine grease as my go-to for years. I use it in everything from my Volvo boat outdrive, Craftsman riding lawn mower spindles, Dexter EZ-lube trailer wheel bearings, to my New Holland tractor backhoe pins, etc. I went to grab a new tube today and noticed that is was now an OBCS (Overbased Calcium Sulfonate) rather than the lithium-complex I've been used to using. I'm worried because the 4 ball wear and the timken load lb ratings have gone down. Will it be okay for the shock loads in the backhoe pins and boat outdrive anymore?
So should I use the new formula or should I look into a different grease? Or am I overthinking it? I'd really like to continue using just one grease for everything.
Current Tech Sheet:
https://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Wayback showing the old Tech Sheet as of 2/2/18:
https://web.archive.org/web/20160413034512/http://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Thank you.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748135
05/04/18 11:02 PM
05/04/18 11:02 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Nope, the OBCS/polymer greases are the big deal today.
Amsoil uses a similar formula.
Infinity is a rather long time - especially towards the end. smile
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748236
05/05/18 07:03 AM
05/05/18 07:03 AM
Indiana
njohnson Online content
njohnson  Online Content
Indiana
In the case of the Timken load lb rating, higher is better. For the 4 ball wear number, lower is better. It means the wear scar being produced is lower. I think that is the way the numbers work. I could be wrong.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4784986
06/12/18 03:27 PM
06/12/18 03:27 PM
ca
monster1 Offline
monster1  Offline
ca
It's been this new calcium based formula for at least a few years now as that's the stuff I bought a few years ago when I replaced an axle with a damaged spindle.
