Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
20 registered members (brianw, billt460, emod, AurionX2, Char Baby, 3 invisible), 893 guests, and 44 spiders.
Topics296,961
Posts4,962,408
Members67,008
Most Online2,821
Jan 21st, 2019
Bosch Pads #4784907
06/12/18 12:46 PM
06/12/18 12:46 PM
IL
lugNutz Offline OP
lugNutz  Offline OP
IL
Howdy folks! Here's my debacle.... Vehicle is a 2014 Passat 1.8T
Bought car used Dec 30, 2017- Brand new brakes- no squeal.
March 2018- Horrible squeal similar to the wear sensor sound. Constant.
May 2018- Pulled pads, hardly any wear at all. Noticed idiots did not apply ANY grease, rubber coating on shim wore off at contact points. Applied grease, squeal went away for about a day.
June 2018- Squeal still there, want to bang head against wall. And so do others nearby.
In summary, I am looking at replacing the pads because the current Bosch pads suck. They tend to slip a bit when braking hard. Not good. I have read conflicting information about whether or not the stock VW brakes in the front are ceramic or semi-met... does anyone have factual knowledge pertaining to the OE pad material OR do you have experience with an aftermarket pad that worked out well for you and wasn't ear-piercing loud on this car? I have used many different brands in the past, all with good results. I am looking to see what would be closest to OE formulation without paying the dealer pricing for this specific vehicle.
'13 Jeep Grand Cherokee Limited | 30K
'14 VW Passat 1.8T SEL Premium | 47K
'05 Ford Explorer XLT | 96k | WIX 51372 | FS 5w-30 (RIP)
Re: Bosch Pads [Re: lugNutz] #4784913
06/12/18 12:52 PM
06/12/18 12:52 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
How about using some of this on the back of the pads:
Originally Posted By: Trav
Originally Posted By: maxdustington
If you can fix it yourself, I would disassemble, clean and re-lubricate. Also, you could try this. I saw Trav recommend it in a different thread.
If the pad and rotor still look ok try to fix it first, your labour is free and the materials are of negligible cost.
Correct. Clean, lube the pins and use CRC Disc Brake Quiet on the back of the pads, reassemble and its done, no more noise 100%.
If it stops okay with these pads regardless of who made them there is no need to toss them.
Re: Bosch Pads [Re: SatinSilver] #4784926
06/12/18 01:06 PM
06/12/18 01:06 PM
IL
lugNutz Offline OP
lugNutz  Offline OP
IL
Isn't that the sticky red stuff? I swear i've used that before on my old Altima and is made the squeal worse.
Re: Bosch Pads [Re: lugNutz] #4784927
06/12/18 01:08 PM
06/12/18 01:08 PM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
Are you only replacing the front brakes or both F & R?
I prefer ceramic and don't even buy semi-mets anymore. Looking at RockAuto, they show mostly ceramic pads however their listing does show some semi-mets as well.
I also prefer brake pads with a Coefficient of Friction(CoF) of "FF" instead of "GG". I like the initial bite of the "FF" better than the "GG". I only see the semi-mets in "EF" of "FG"(maybe "FF") and I can't answer for that.
Also, get new pads with the hardwear already included and install them after cleaning the hold down bar(pad slots) thoroughly. Grind out the rust, don't use a wire wheel as it only shines up the rust.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Bosch Pads [Re: lugNutz] #4784929
06/12/18 01:13 PM
06/12/18 01:13 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I believe so, here's the thread with a new more tips on using it.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4765196/2
Re: Bosch Pads [Re: lugNutz] #4784944
06/12/18 01:23 PM
06/12/18 01:23 PM
USA
slacktide_bitog Offline
USA
Akebono makes good pads that are nice and quiet and don't dust smile
Re: Bosch Pads [Re: slacktide_bitog] #4784952
06/12/18 01:36 PM
06/12/18 01:36 PM
IL
lugNutz Offline OP
lugNutz  Offline OP
IL
Agreed. Have used them in the past amongst many others. I like the Wagner TQs too but according to RA, they are semi-met.
Curious how good Centric posi-quiets are now- have yet to try those.
Re: Bosch Pads [Re: lugNutz] #4784956
06/12/18 01:49 PM
06/12/18 01:49 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Put some Wagner OEX pads on the rear of the Camry a year ago. Have been happy with those. Quiet as a mouse. Since you mention Wagner.
Re: Bosch Pads [Re: lugNutz] #4784963
06/12/18 02:02 PM
06/12/18 02:02 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Did they replace or turn the rotors when they did the pads?
2015 Hyundai Sonata 2.4L 90k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Bosch Pads [Re: Nick1994] #4784965
06/12/18 02:04 PM
06/12/18 02:04 PM
IL
lugNutz Offline OP
lugNutz  Offline OP
IL
Honestly, I cannot speak to either one of those. All I know is that the dealership I bought it from took care of it before they put it up for sale. Wish I knew. If I go the route of replacing the pads, I would have the rotors turned.
Re: Bosch Pads [Re: lugNutz] #4784976
06/12/18 02:14 PM
06/12/18 02:14 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
ATE, Textar, Pagid, Jurid, EBC Ultimax. any one of them will work well, sauce them a little on the back of the pads. Some VW's are notorious for brake squeal without OE pads.
Re: Bosch Pads [Re: lugNutz] #4785018
06/12/18 03:13 PM
06/12/18 03:13 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
You are criticizing Bosch pads, but you don't say what model they are and if they were installed with new rotors. Bosch makes three grades of brake pads. I just had Bosch Quietcast ceramic pads along with new Brembo rotors installed on the front of my M35. Smooth and quiet with no issues at all. Rotors are a fraction of what they used to cost. Don't turn them, buy new.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Bosch Pads [Re: NormanBuntz] #4785050
06/12/18 03:55 PM
06/12/18 03:55 PM
wv
krismoriah72 Offline
wv
the rubber coating is likely not sliding smoothly on the pins giving you chatter. I would try one more time filing or burning off the rubber coating...and lubing the pins and ears.
Otherwise my next new pads are likely going to be Raybestos EHT ...they seem to have the best of all worlds and reasonably priced.
Re: Bosch Pads [Re: lugNutz] #4785101
06/12/18 04:41 PM
06/12/18 04:41 PM
California
nthach Offline
nthach  Offline
California
FWIW, I have Bosch's private label rebrand of their QuietCast pads on a friend's Subaru and so far, so good. He even reports they work better than the Wagners that I installed before that.
Re: Bosch Pads [Re: SatinSilver] #4785173
06/12/18 06:00 PM
06/12/18 06:00 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Correct. Clean, lube the pins and use CRC Disc Brake Quiet on the back of the pads, reassemble and its done, no more noise 100%. If it stops okay with these pads regardless of who made them there is no need to toss them.
Sweet advice, thanks!!
