HF Recall on 14" Electric Chainsaw
by SubLGT. 06/17/19 05:34 PM
Does the GM G80 need LS fluid?
by K20FA5. 06/17/19 05:07 PM
Pink Seats LS430
by Gebo. 06/17/19 04:58 PM
No 5w20 A5/B5 oil?
by SlavaB. 06/17/19 04:51 PM
Dexos2 for GTDI engines (EcoBoost, GM, etc)
by metroplex. 06/17/19 04:36 PM
GM X-Cars
by GumbyJarvis. 06/17/19 04:21 PM
Do downstream O2 ever get poisoned?
by PandaBear. 06/17/19 03:51 PM
Sharing files
by Chester11. 06/17/19 03:25 PM
Fumoto valves
by cwilliamsws6. 06/17/19 03:12 PM
Who goes to beaches for vacation?
by 53' Stude. 06/17/19 02:35 PM
What would make BITOG better?
by Hastrup. 06/17/19 01:44 PM
Adhesive sealant FTW!
by mclasser. 06/17/19 01:29 PM
1985 Toyota Camry.. Any tips?
by spavel6. 06/17/19 01:20 PM
AAP 25% off
by rollinpete. 06/17/19 12:52 PM
TCW3 and direct injection
by ARB1977. 06/17/19 12:45 PM
Brake bleeding procedure
by painfx. 06/17/19 11:28 AM
5W20 walmart Full Syn bad smell
by ragtoplvr. 06/17/19 11:18 AM
Leaving Amsoil Ea15k filter for 2 oil changes?
by metroplex. 06/17/19 11:15 AM
Just did my 1st CVT fluid change
by Char Baby. 06/17/19 10:24 AM
TallTravel, MrTire, Skraeling, Metalmanx48, Cannedcreamcorn
68420 Registered Users
120 registered members (AC1DD, 4WD, AlaskaMike, 77GrandPrix, addyguy, AlienBug, 9 invisible), 2,284 guests, and 13 spiders.
Topics290,586
Posts4,988,925
Members68,420
Most Online2,967
Mar 10th, 2019
Bleeding air from cooling system - Zetec #4784065
06/11/18 04:32 PM
06/11/18 04:32 PM
NE Ohio
Ifixyawata Offline OP
NE Ohio
Hi all:
I've read differing opinions but I know there are some very knowledgeable Zetec/Focus people on this board. I have had a seeping, developed to full blown leaking heater/coolant hose on my Focus and I just replaced it today. It's the one the runs from the thermostat housing to the front plastic'crossover' pipe, I didn't lose much coolant at all replacing it, I topped off the coolant tank and ran the car for about 5 minutes. The heat works and the hose is getting hot.
Do I need to burp air out of the cooling system on this car? I've read that because it's a pressurized tank, yadda yadda that it's sort of self-burping.
2004 Mercury Mountaineer 4.6 M1 High Mileage 10w-40 (Summer)
2001 Ford Focus 2.0 Zetec Pennzoil Euro L 5w-30
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784077
06/11/18 04:44 PM
06/11/18 04:44 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
If the heat works and the hose is getting hot - and I'm assuming this also means your heater puts out HOT air, not just warm - then I'd say you're not in any immediate danger. If I were in your shoes, I'd take the car out, somewhere close to home, and put it through the paces for 5-10 minutes.. Try your best to keep it at a somewhat consistent RPM range between 2000 and 2500 RPM. This should force any remaining bubbles of air to a spot they can burp out naturally.
Make sure you keep a close eye on the temperature while you're doing this, just to be safe.
Where I live, there's a highway very close by, with an exit near me, and another about 3 miles down. IMHO, this would be the perfect place. Get it up to highway speed, hold it at RPM, get off after 3 miles, turn around and go back.
2013 Nissan Altima SV - 2.5 liter/CVT - 113,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 65,000mi
2010 Ford Fusion - 274,000mi
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784083
06/11/18 04:52 PM
06/11/18 04:52 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I just keep topping off the coolant every morning until it can't take any more.
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784122
06/11/18 05:48 PM
06/11/18 05:48 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Never had to bleed it on my old ZX5 when I changed the thermostat housing. If the level in the pressurized tank goes low, just top it off when the system is cold.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784131
06/11/18 05:54 PM
06/11/18 05:54 PM
USA
slacktide_bitog Offline
USA
The Focus Zetec is one of the easier cars to bleed the coolant on. Just fill it, leave the cap open, turn the heat to full blast, let it warm up, and wait for the bubbles to stop.
Of course, if you're still having trouble with it, the Lisle funnel is awesome smile
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784156
06/11/18 06:16 PM
06/11/18 06:16 PM
ME
eljefino Online content
eljefino  Online Content
ME
Some cars that bleed hard, I remove the top radiator hose from the radiator and stretch it up as high as it'll go, and pour coolant in that to back-force it through the engine until it dribbles out the now-open radiator. This with the car on ramps so it's a higher spot.
Some cars with the thermostat up top make this hard, IDK how the zetec does it.
I think you should keep doing what you're doing. Grab the top hose and massage it to feel if you have any bubbles.
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784201
06/11/18 06:53 PM
06/11/18 06:53 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
As Kestas said keep topping it off til it stabilizes, if the hose is getting hot you have circulation and it will expel the air after a few cool downs.
Hard to bleed engines are becoming more common in the US but in Europe its been a problem for years especially on some diesels.4
Vacuum filling is the only way to get system filled quickly and air free, I highly recommend a vacuum filler for anyone doing DIY cooling system service.
Right now ECS tuning has a great unit on sale for under $60, they have a sale on it a few times a year. It is a well made quality piece at a great price.
https://www.ecstuning.com/b-schwaben-parts/coolant-refill-air-purge-tool/003466sch01/
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784242
06/11/18 07:37 PM
06/11/18 07:37 PM
The land of USA-made Subies!
SubieRubyRoo Offline
I 2nd Trav's note about vacuum units. My brother is a wrench also, and he says there are some Chevys and other vehicles that are darn near impossible to bleed without using a vacuum unit. If you can't use the Lisle funnel or have the bleeder line like the Ford/Mazda 2.5s, vacuum bleeder may be your best friend.
Re: Bleeding air from cooling system - Zetec [Re: Trav] #4784500
06/12/18 04:31 AM
06/12/18 04:31 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Thanks for posting! I grabbed one. Some cooling systems I've encountered can be a PITA to bleed.
God Bless Our Troops
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784515
06/12/18 05:41 AM
06/12/18 05:41 AM
NE Ohio
NE Ohio
Thank you all for the replies. I turned on the bluetooth OBDII scanner and watched my coolant temp on my ride in to work, seemed to run about 210 - 220 the whole time except for the brief period of "robust accelleration" where it did hit 233, but it came right back down into the 215 range quickly.
When I got to work I opened the hood with it still running and checked and lo and behold I still had coolant. I verified by opening the cap as you can't really see through the old clear bottle very well but sure enough there's coolant in there. What's strange is there didn't seem to be any hiss or relief of pressure when I opened the overflow tank/bottle, and the coolant in there was really only warm to the touch. Yes, I touched it because curiosity. Is this normal?
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784588
06/12/18 07:24 AM
06/12/18 07:24 AM
Trav Offline
Trav  Offline
Sounds like there may be air in there somewhere.
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784805
06/12/18 11:43 AM
06/12/18 11:43 AM
NE Ohio
NE Ohio
I'm currently taking my lunch break in my car, have it running with the cap off, well see if this helps
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784810
06/12/18 11:51 AM
06/12/18 11:51 AM
Trav Offline
Trav  Offline
Be careful not to overheat the thing, then you have a problem. Check fan operation, make sure it is coming on and going off when the temp drops.
Re: Bleeding air from cooling system - Zetec [Re: Trav] #4784817
06/12/18 11:57 AM
06/12/18 11:57 AM
NE Ohio
NE Ohio
Been running at idle for about 15 minutes and just now at 200F
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784845
06/12/18 12:24 PM
06/12/18 12:24 PM
KrisZ Offline
KrisZ  Offline
You may want to increase the revs a bit, to about 1500-2000 RPM. It will speed up the bleeding process. Monitor the temps during this time of course.
