Valvoline Premium Blue 8600 ES 15W40
by 53' Stude - 09/21/19 01:20 PM
Axle shaft seal leak?
by aquariuscsm - 09/21/19 01:14 PM
Refills for Denso Designer wipers
by mclasser - 09/21/19 12:45 PM
What make steering wheel hard to turn
by Rohan - 09/21/19 12:43 PM
Z55 coil spring options
by LeakySeals - 09/21/19 12:28 PM
diy AA Solar charger?
by earlyre - 09/21/19 11:53 AM
Would you worry about this tire for 6K miles?
by MoneyJohn - 09/21/19 11:34 AM
TCW3 fuel mix
by otis24 - 09/21/19 10:44 AM
FRAM XG4967 C&P ~18,000 kms
by mcwilly - 09/21/19 10:16 AM
Any reason not to use high mileage formula oil?
by jimbrewer - 09/21/19 10:03 AM
Holley carb only works on cold engine
by liberty - 09/21/19 10:01 AM
turbo cool down
by mobilaltima - 09/21/19 09:04 AM
10K Mile Oil Change - 1.8L TSI Jetta
by SandCastle - 09/21/19 08:08 AM
Pennzoil Platinum 10w30 HTHS
by donnyj08 - 09/21/19 07:56 AM
Mortality stats
by CourierDriver - 09/21/19 07:38 AM
Is it time for a brake fluid flush?
by A_A_G - 09/21/19 03:22 AM
Take that!
by Mad_Hatter - 09/21/19 03:18 AM
02 Honda Accord V6 Aluminum Radiator
by David1 - 09/21/19 01:55 AM
Difinitive Answer for SCA, Silicates, and Diesels
by ErikLeifson - 09/20/19 11:11 PM
Quart bottle cap
by maverickfhs - 09/20/19 11:11 PM
OilReport99, TungGT, ErikLeifson, Kinnes25, Bamajoe
69348 Registered Users
78 registered members (ammolab, 97prizm, 69GTX, 64bawagon, 10 invisible), 2,443 guests, and 36 spiders.
Topics294,863
Posts5,068,240
Members69,348
Most Online3,532
Jul 30th, 2019
Car window tint quality #4784508 06/12/18 05:08 AM
O
OilUzer Offline OP
O
How long does after market tinting last these days?
I see a lot of cars with peeling windows or with bubbles!
Can it last 10 or 15 years without peeling off or bubbles?
They all give you a life time warranty but 3 years later the business is gone! wink
Re: Car window tint quality [Re: OilUzer] #4784509 06/12/18 05:12 AM
J
JC1 Offline
J
I've had my wife's civic tinted for at least 15 years. No issues with it.
Had an accord I kept for 8 years and a sienna for 9 years and no issues in those. On the caravan I've had the front doors tinted two years ago.
I guess it depends on who installed it and the quality of the tint film.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Car window tint quality [Re: OilUzer] #4784552 06/12/18 06:48 AM
B
billt460 Online Content
Online Content
B
The tint on my 1991 F-150 is still fine. I had it put on almost 27 years ago, shortly after I bought the truck. I think how long it lasts depends more on how it's installed, than what type. The best grade tint won't hold up if it's not applied properly. Also, it can be damaged over time by using too harsh of a cleaner. Stay away from Ammonia based window cleaners. All I have ever used on mine is plain water, per what the installer told me.
Re: Car window tint quality [Re: billt460] #4784560 06/12/18 06:55 AM
K
klt1986 Offline
K
+1 on staying away from the ammonia based cleaners.
The tint on my wife's CR-V is 10 years old and it is 6 years old on my Tundra. Both are holding up fine. My son's Corolla is also holding up fine but the tint is only 2 years old on it.
Re: Car window tint quality [Re: OilUzer] #4784576 06/12/18 07:08 AM
blupupher Offline
Last place that I had my tint done has been in business for over 15 years at the same place.
on my '04 Elantra I had the tint replaced, once for the rear window bubbling @ about 5 years (needed it again at the time I sold it) and while they did that I had them do the other windows due to tint fade. This was in the 10 years.
No charge for any of the replacement. So while it was about 5 years that it lasted, having a shop that has been around can make a difference.
Also the quality of the tint itself makes a big difference.
They have done 3 other vehicles of mine as well.
Wife's car has the front windows that were done and still look great 5 years later (using Suntek CXP 55% tint)
2018 Santa Fe: PP 10W-30/OEM/5k
2018 Soul: Mobil Super 5W-20/OEM/5k
2012 xB: M1 EP 0W-20/CQ Blue/5k
2002 F150: Magnatec 5W-20/Bosch D+/1yr
1994 VT1100: Peak 15W-40/Bosch D+/1yr
Re: Car window tint quality [Re: OilUzer] #4784579 06/12/18 07:13 AM
T
talest Offline
T
Llumar is a good brand of tint.
Re: Car window tint quality [Re: OilUzer] #4784605 06/12/18 07:40 AM
T
thescreensavers Offline
T
There are good and bad ones, dont buy a bad one and it will likely last the lifetime of the vehicle. When you see the 60$ tint specials they are not using quality tint.
Look for 3M,Llumar,Suntek...etc these are better brands yes a little more expensive but will last and not bubble and turn purple.
I personally have Formula One Pinnical by Llumar on my Camaro and another cheaper Llumar tint on my Jeep both work great in the Florida sun.
Just like oil, Tint has its own PDS which will list its specs
Llumar/Formual1: http://cdn.llumar.com/drupal/formulaonellumarautomotivespecifications2018january.pdf
suntek https://www.suntekfilms.com/Files/SunTek%20Auto%20Specs.pdf
3M http://solutions.3m.com/3MContentRetriev...ibute=ImageFile
For example in S.FL I care about total solar/heat rejection.
If the shop I installed my tint at goes under, I just find the next Llumar dealer and bring my receipt no issues.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Car window tint quality [Re: talest] #4784608 06/12/18 07:44 AM
M
mightymousetech Offline
M
This.
There are HUGE differences in quality of tint film. I have Llumar cermaic CTX tints on my cars, but there are even better quality films out there now.
If you get dyed films, they will fade, they all do eventually. Metallic tints are better but they block signals of things like cell phones, remotes etc etc. Ceramic is like metallic, as in it won't fade, but will not block radio frequency signals.
Also big difference in amount of heat rejected vs darkness of tint. You can go with a lighter ceramic tint and get better heat rejection than a dark dyed film.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, Castrol 0W40, MT-LV
Re: Car window tint quality [Re: OilUzer] #4784705 06/12/18 09:28 AM
R
Rat407 Offline
R
Is there such a thing as a film that is clear but rejects UV rays and heat? Like can be applied to the windshield and be legal?
2002 Silverado 5.3 0w-20 AMSOIL
Re: Car window tint quality [Re: Rat407] #4784729 06/12/18 09:54 AM
SatinSilver Offline
One of the best tint shops around here that's been business a long time charges $300-400-500 for 3M tint. The $300 package has a 5 year warranty and longer warranties on the more expensive options. So not cheap at all.
Re: Car window tint quality [Re: OilUzer] #4784791 06/12/18 11:19 AM
K
KrisZ Offline
K
I tinted my Mazda 3 12 years ago. The film looks perfect, no bubbles or anything, but it has faded to the point that it almost looks like clear glass. I don't remember what brand it is. I tried peeling it off with a heat gun, but after so many years it's stuck in there pretty good. So I have to live with it.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Car window tint quality [Re: talest] #4784809 06/12/18 11:48 AM
L
Lolvoguy Offline
L
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Car window tint quality [Re: OilUzer] #4785075 06/12/18 05:18 PM
The Critic Offline
My daily driver has Huper Optik ceramic film and it still looks and performs well after 7 years.
Ceramic films seem to offer great heat rejection and decent longevity. I recommend 3M Crystalline if it is in your budget, but it is about $1k to do a car.
2011 Toyota Prius 1.8L - 197K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: Car window tint quality [Re: Rat407] #4785133 06/12/18 06:09 PM
blupupher Offline
It is illegal in all 50 states to tint the windshield to any degree, but many do it with as high as 30%.
I know 3M has a 90% tint (only 10% light blocked) that is their top of the line tint that blocks heat better than most competitors darker top tier tints.
My wife does not like dark tint at all, so she only has 55% on her front windows and whatever is stock tint from the factory, but after seeing this 3M stuff, that my be her next tint, regardless of price.
Re: Car window tint quality [Re: OilUzer] #4785435 06/13/18 02:52 AM
F
Falcon_LS Offline
F
I've got Huper X3 Ceramic 40 Series all-round on my vehicles, except the windshields which has Nano-Ceramic 70. Huper Optik is part part of Eastman Chemical Company like Llumar.
Never had any issues, but again I use plain water with a touch of soap to clean it - no harsh chemicals.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
