What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
129 registered members (4WD, 01rangerxl, 92saturnsl2, 2010Civic, ABerns, 2009Edge, 10 invisible), 2,191 guests, and 63 spiders.
Topics286,030
Posts4,901,129
Members67,549
Most Online2,967
Mar 10th, 2019
Will I need torque wrench to do strut bolts? #4784795
06/12/18 11:27 AM
06/12/18 11:27 AM
stamford, CT
ziggy Offline OP
ziggy  Offline OP
stamford, CT
Hi all! Time for new struts,98 buick lesabre.I've done struts,before,never used a torque wrench. Watching some YouTube vids last night, front struts,they used a big torque wrench,for the 2 bolts,bottom end of struts. 140 ft.lbs. I figured,use use a breaker bar, socket,and tighten till it won't tighten no more. Would that work,or torque wrench mandatory?
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784798
06/12/18 11:31 AM
06/12/18 11:31 AM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Mandatory? No..
.. but I would HIGHLY recommend you use one. You don't mess with suspension components.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784803
06/12/18 11:36 AM
06/12/18 11:36 AM
Georgia
AVB Offline
AVB  Offline
Georgia
A pull handle will be fine, I use a impact.
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784808
06/12/18 11:47 AM
06/12/18 11:47 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
140 ft.lb isn't as much as you think, you can easily put over 250 ft.lb on a 24" breaker bar. Use a TW, experienced feel has its place ham fisted does not.
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784811
06/12/18 11:51 AM
06/12/18 11:51 AM
stamford, CT
ziggy Offline OP
ziggy  Offline OP
stamford, CT
I've done struts before,no issues...just made me think,what if,you know? I've always used a breaker bar,socket,tighten till it won't tighten anymore,than give a good 1/4 too half turn..
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784814
06/12/18 11:55 AM
06/12/18 11:55 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
If they are pinch bolts just crank them with the breaker bar, or impact. A few impact pulses probably puts it around there? Rust will help keep it tight, lol.
What you should really have the TW for is the nut on top of the strut that connects it to the strut mount. On my car, you need special tools to torque it. I never do and feel guilty afterwards.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784822
06/12/18 12:01 PM
06/12/18 12:01 PM
CA
The Critic Online crying
The Critic  Online Crying
CA
I recommend impacting to spec, which means holding down the trigger until the bolt stops turning. wink
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: Will I need torque wrench to do strut bolts? [Re: The Critic] #4784825
06/12/18 12:04 PM
06/12/18 12:04 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
Exactly one brap.
But in all seriousness, use a torque wrench.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784833
06/12/18 12:12 PM
06/12/18 12:12 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Exactly one brap When Charlie worked on his'47 chain drive Sterling he used "creaks" grin2
Thick oil is better grin2
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784837
06/12/18 12:17 PM
06/12/18 12:17 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
If it goes to "crack" it's too much. A torque wrench can be had for $50.
If you want the job done right......do it yourself.
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784852
06/12/18 12:34 PM
06/12/18 12:34 PM
stamford, CT
ziggy Offline OP
ziggy  Offline OP
stamford, CT
It's the bottom 2 bolts,not the top end ones,front of struts. Oh!those 2 boltd..are they also,the camber bolts? Be also known as clevis bolts.might wanna get 4 new ones.
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784935
06/12/18 02:19 PM
06/12/18 02:19 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
AZ, Advanced, or O'Reilly's has loaners you can use for free.
Check back on my previous posts to see how you can validate calibration with a bench vise and free weight.
There is no reason not to do this right.
2001 Mitsubishi Galant 2.4 - 162k+
Grandma's creampuff...
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4784945
06/12/18 02:24 PM
06/12/18 02:24 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
You don't really need to, but a torque wrench is like $10-20 at Harbor Freight smile
Re: Will I need torque wrench to do strut bolts? [Re: slacktide_bitog] #4784973
06/12/18 03:08 PM
06/12/18 03:08 PM
Trav Offline
Trav  Offline
Better than attacking it with a breaker bar till it wont go any tighter or it breaks and he ends up on his arse breaker bar, socket, broken bolt and all.
Re: Will I need torque wrench to do strut bolts? [Re: ziggy] #4785111
06/12/18 05:46 PM
06/12/18 05:46 PM
ME
eljefino Offline
eljefino  Offline
ME
Those bottom bolts are massively huge, way bigger than lug studs. I give them serious beans. If you have camber slots in your new struts the friction/clamping force of those bolts is the only thing holding your alignment kosher.
Break them loose with your breaker bar and develop the muscle memory of that event.
