Adhesive sealant FTW!
by mclasser. 06/17/19 01:29 PM
1985 Toyota Camry.. Any tips?
by spavel6. 06/17/19 01:20 PM
AAP 25% off
by rollinpete. 06/17/19 12:52 PM
TCW3 and direct injection
by ARB1977. 06/17/19 12:45 PM
Brake bleeding procedure
by painfx. 06/17/19 11:28 AM
5W20 walmart Full Syn bad smell
by ragtoplvr. 06/17/19 11:18 AM
Leaving Amsoil Ea15k filter for 2 oil changes?
by metroplex. 06/17/19 11:15 AM
Just did my 1st CVT fluid change
by Char Baby. 06/17/19 10:24 AM
Saab 9-3 Carrier Bolts - 155 ft lbs
by ET16. 06/17/19 09:15 AM
Fran CA11480
by jcartwright99. 06/17/19 08:43 AM
Recommend oil for 2020 Kia Soul 2.0L
by Hoot_r. 06/17/19 08:40 AM
Why does Amsoil market the way it does?
by Redright9. 06/17/19 08:36 AM
'11 CTSV - M1EP 10w30 - 8K Built LSA - ~2k sample
by oilnoob32. 06/17/19 08:34 AM
Blue smoke and Mobil 1 Syn High Milage!!
by Kestor. 06/17/19 08:03 AM
crank and water pump pulleys stuck
by slybunda. 06/17/19 07:50 AM
2018 Mazda6 oil choice?
by gabriel9766. 06/17/19 07:33 AM
The Real Scoop
by RayCJ. 06/17/19 06:08 AM
time based timing belt change question
by berniedd. 06/17/19 03:18 AM
Vtwin rod bearings with synthetic oil
by kawie_guy. 06/17/19 02:25 AM
BG MOA is now LSPI "safe"
by The Critic. 06/17/19 12:42 AM
Skraeling, Metalmanx48, Cannedcreamcorn, Kestor, Slipcase
68418 Registered Users
97 registered members (alphadog, AC1DD, 2012AccentSE, 53' Stude, 87sammy, ad244, 12 invisible), 2,327 guests, and 23 spiders.
Topics290,573
Posts4,988,691
Members68,418
Most Online2,967
Mar 10th, 2019
2017 WRX STI: Motul X-clean EFE - 5,000 miles #4784224
06/11/18 07:16 PM
06/11/18 07:16 PM
Florida
Tiir Offline OP
Tiir  Offline OP
Florida
Motul X-clean 5w-30 EFE fill.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784236
06/11/18 07:28 PM
06/11/18 07:28 PM
MN
oil_film_movies Offline
MN
Copper is probably from the oil cooler. Its been seen a lot on WRX engines. The other possible source is the crank bearings, yet it just seems unlikely here.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784565
06/12/18 06:58 AM
06/12/18 06:58 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
For what itís worth that is a very low iron number, down at 1 ppm/ 1000 miles. Where the other checks with the same Motul oil?
If you want the job done right......do it yourself.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784694
06/12/18 09:18 AM
06/12/18 09:18 AM
Samara, Russia
Gubkin Online content
Gubkin  Online Content
Samara, Russia
"TBN is still good at 2.2. Try 7000 miles"
Crazy lab! )))))))
It's mean that TBN > TAN
necessary decrease interval to 4000 miles
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784713
06/12/18 09:32 AM
06/12/18 09:32 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What?
Crazy lab! )))))))
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784735
06/12/18 10:00 AM
06/12/18 10:00 AM
Samara, Russia
Samara, Russia
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784746
06/12/18 10:07 AM
06/12/18 10:07 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Very good metal wear rates.
Cu and (part of) Al likely comes from cooler, not bearing.
This C3 oil of TBN 7.8 drops to 2.2 over 5100 miles, which I interprete as good TBN retention.
I won't look at TAN , if any, and agree with BStone OCI could be extended further to 7000 miles or probably beyond.
Edit:The test of the pudding is in the eating, which in this case refers to (the very good) Fe wear of 5 ppm over 5100 miles.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784786
06/12/18 11:10 AM
06/12/18 11:10 AM
NJ
bluesubie Offline
bluesubie  Offline
NJ
I believe that Blackstone uses a different ASTM test than either of those (at least they used to).
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=221275
I doubt the OP will extend the interval very much. And probably not likely to go beyond 6k miles which is Subaru of America's recommendation unless Blackstone will cover the Powertrain Warranty. smile2
'04 Subaru Forester 2.5XT
Castrol Edge 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4784788
06/12/18 11:15 AM
06/12/18 11:15 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Wear metals ppm is only a piece of the story. You will not see deposit formation in a UOA, which you get from low TBN or where TAN is higher than TBN.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4785143
06/12/18 06:29 PM
06/12/18 06:29 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What is the TAN here?
1994 BMW 530i, 242K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: 1JZ_E46] #4785163
06/12/18 06:48 PM
06/12/18 06:48 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Deposit formation,contents of Na,Ca,Mg etc, sludge,varnish,low TBN , high TAN,residual [email protected]*C, fuel dilution % etc are merely/strictly noises.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4789145
06/17/18 12:42 PM
06/17/18 12:42 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Respectfully disagree. What a dense statement.
