Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Helicopter
by Exhaustgases - 01/28/20 01:25 AM
Shell Helix Ultra 5W-30
by SR5 - 01/28/20 12:30 AM
Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Towkid, denor, Jubaxtreme, CAJ1966, Shiza
70550 Registered Users
92 registered members (14Accent, AlaskaMike, 01rangerxl, 1978elcamino, 53' Stude, 1WildPig, 3 invisible), 3,129 guests, and 17 spiders.
Topics300,673
Posts5,180,878
Members70,550
Rust Converter #4784353 06/11/18 08:16 PM
CCI Offline OP
Anyone have any good or bad experience withthe products that are designed to be applied to rusted metal to stop the progress of the corrosion?
Rust Converter #4784357 06/11/18 08:18 PM
CCI Offline OP
Anyone have any good or bad experience with the products that are designed to be applied to rusted metal to stop the progress of the corrosion?
This is for a motorcycle that was left sitting outside too long.
Re: Rust Converter [Re: CCI] #4784369 06/11/18 08:33 PM
G
Gixxer46 Offline
G
POR15! Then top coat it with another rust paint as POR15 is UV sensitive.
Iíve had great luck with this on the undercarriage of my truck.
2013 Ram 1500 with a 4.7.
I use 0W-20 year round. I alternate between RP and Amsoil Signature series.
Re: Rust Converter [Re: CCI] #4784383 06/11/18 08:50 PM
A
andyd Offline
A
Sorta, I was fixing a flat on my oldest 2 wheel cart. The rim was getting very rusty, I had an old spray can of Rustoleum Rust Reformer. It had lost its fizz. Can was maybe 20 yrs old. I poured it out of a hole and painted the rim inside What spilled on the outside looks good. If I could score some on sale, I would paint both wheels.
Thick oil is better grin2
Re: Rust Converter [Re: CCI] #4784394 06/11/18 09:09 PM
M
maxdustington Online Content
Online Content
M
Yeah: Ospho
I live in Canada, I have figured out how to destroy rust (without immersion):
1. Sandblast to get the scale off.
2. Acid to remove the rust from inside the pits + etch so that paint will stick.
99 Toyota Tercel CE 5EFE/C151
Re: Rust Converter [Re: CCI] #4784426 06/11/18 09:43 PM
R
researcher Offline
R
each post has a different recommendation.. Ok, I'll throw mine in. Eastwood's rust encapsulator. I've used that and it's not bad, their converter gets mixed reviews. I has stopped the rust I have on my project Civic car.
eastwood.com look for rust encapsulator. I had tried SEM products version of this type of thing and it needed precise temp/humidity to work. Sure the only time we get that humid and hot is august! So I went with eastwood and it worked no matter what humidity level, but above I think 55 or 60degrees ambient temps.
Re: Rust Converter [Re: Gixxer46] #4784521 06/12/18 04:51 AM
J
JLTD Offline
J
Doesn't the POR15 use a chemical process to change the rust to some sort of polymer? I recall using this or something similar years ago, turned the rust black and stopped it...
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, 35k, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Rust Converter [Re: JLTD] #4784523 06/12/18 05:01 AM
N
NGRhodes Offline
N
https://en.wikipedia.org/wiki/Phosphoric_acid#Rust_removal
Re: Rust Converter [Re: CCI] #4784525 06/12/18 05:04 AM
L
Lubener Offline
L
I have always used Ospho.
The "thinking" man's friend.
Re: Rust Converter [Re: CCI] #4784604 06/12/18 06:40 AM
T
Trav Offline
T
I have used literally dozens of them over the years and they all have one thing in common, they all suck Por 15 included.
Needle scaler or stiff wire wheel/brush and wet the part with $1 a gallon 5% vinegar. Wrap the part (if possible) with old newspaper and wire wrap it to hold it in place and soak it down with the vinegar.
Let it sit a few hours and remove, wire brush or scrub pad it down with water and baking soda, fresh water rinse and dry.
paint with self etching primer, the spray can works fine. Topcoat and rust proof.
Re: Rust Converter [Re: Trav] #4784649 06/12/18 07:22 AM
Delta Offline
Hmm, glad you posted this! Was planning on doing some rust remediation on the truck when I have the bed off for fuel pump replacement. What kind of topcoat or rust proofing would you go with? I was going to wire wheel with my grinder everything and do something like POR15. But maybe not now.
'17 VW GTI 2.0T - 6MT - 19K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 138K - RGT 5w30
Re: Rust Converter [Re: Delta] #4784693 06/12/18 08:18 AM
T
Trav Offline
T
You need a thick layer of newspaper to hold a good bit of the vinegar so it doesn't dry out too fast, wrap it good and give it a good soaking after you wire wheel it.
You must neutralize the acid with baking soda and water with a fresh water rinse once its reasonably clean then dry it.
Prime with self etching primer, rattle cans work okay but I like a 2 part epoxy with a spray gun if possible.
Once is clean, dry and primed use chip guard on it. NAPA has good stuff in rattle cans cheap enough, the part # for black is MS 4004. If its clean and dry and primed this stuff will hang in there forever, it is hard to remove and really resist rocks and stone damage.
Coat it well with a couple of coats and let it dry. Once its dry cover that with 3M 03584 rubberized undercoating, let it dry well overnight before reassembly. It wont rust even in the salt belt, care of application is everything.
Re: Rust Converter [Re: CCI] #4784711 06/12/18 08:31 AM
T
thescreensavers Offline
T
For fixing rust on my Jeep, first I cut out most I could once you have through rust it needs to be cut. For surface rust/pitting I wire wheeled and flapper wheeled where I could and used Rustoleum Rust Dissolver Spray/Gel which is Phosphoric Acid. Let that sit and use a brass brush to scrub it in. Then I used a wet towel to get the product off then used rustoleum roll on paint, Rusty Metal Primer + Paint. The Paint is very durable and cheap.
Before and After
https://imgur.com/a/QRj1Ykg
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Rust Converter [Re: CCI] #4784723 06/12/18 08:45 AM
Donald Offline
Loctite Extend is supposed to be a converter and paint. Its pretty good. Others use something like naval jelly to convert, then use POR-15 or Eastwood Rust Encapsulator as a covering to block any oxygen from getting to the surface. You cannot sand POR-15 or Eastwood Rust Encapsulator but can paint over them. If you can dip the item then there are other products.
Sand or sandblast and paint with self etching primer is another method.
2015 Ford F-250 w/Powerstroke
