Ebay $15 of $75 purchase
by GMguy84 - 11/19/19 12:06 AM
How thorough are coolant flushes at auto shops?
by Whammo - 11/18/19 10:58 PM
Fixed Orifice PCV design and issues.
by Talent_Keyhole - 11/18/19 10:44 PM
Redline Si-1 turning the light out
by lukejo - 11/18/19 10:16 PM
Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
20 registered members (carlprop, clinebarger, CharlieBauer, Brad_C, 2000Trooper, Aero540T, 2 invisible), 930 guests, and 20 spiders.
Topics297,616
Posts5,119,359
Members69,908
Most Online3,589
Nov 2nd, 2019
2017 WRX STI: Motul X-clean EFE - 5,000 miles #4784224 06/11/18 06:16 PM
T
Tiir Offline OP
T
Motul X-clean 5w-30 EFE fill.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784236 06/11/18 06:28 PM
O
oil_film_movies Offline
O
Copper is probably from the oil cooler. Its been seen a lot on WRX engines. The other possible source is the crank bearings, yet it just seems unlikely here.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784565 06/12/18 05:58 AM
Snagglefoot Offline
For what it’s worth that is a very low iron number, down at 1 ppm/ 1000 miles. Where the other checks with the same Motul oil?
If you want the job done right......do it yourself.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784694 06/12/18 08:18 AM
G
Gubkin Offline
G
"TBN is still good at 2.2. Try 7000 miles"
Crazy lab! )))))))
It's mean that TBN > TAN
necessary decrease interval to 4000 miles
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784713 06/12/18 08:32 AM
K
kschachn Offline
K
What?
Crazy lab! )))))))
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784735 06/12/18 09:00 AM
G
Gubkin Offline
G
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784746 06/12/18 09:07 AM
Z
zeng Offline
Z
Very good metal wear rates.
Cu and (part of) Al likely comes from cooler, not bearing.
This C3 oil of TBN 7.8 drops to 2.2 over 5100 miles, which I interprete as good TBN retention.
I won't look at TAN , if any, and agree with BStone OCI could be extended further to 7000 miles or probably beyond.
Edit:The test of the pudding is in the eating, which in this case refers to (the very good) Fe wear of 5 ppm over 5100 miles.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784786 06/12/18 10:10 AM
B
bluesubie Offline
B
I believe that Blackstone uses a different ASTM test than either of those (at least they used to).
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=221275
I doubt the OP will extend the interval very much. And probably not likely to go beyond 6k miles which is Subaru of America's recommendation unless Blackstone will cover the Powertrain Warranty. smile2
'20 Subaru Outback Onyx XT | FF Idemitsu 0W-20
'04 Subaru Forester 2.5XT | Edge 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4784788 06/12/18 10:15 AM
1
1JZ_E46 Offline
1
Wear metals ppm is only a piece of the story. You will not see deposit formation in a UOA, which you get from low TBN or where TAN is higher than TBN.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4785143 06/12/18 05:29 PM
K
kschachn Offline
K
What is the TAN here?
1994 BMW 530i, 250K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: 1JZ_E46] #4785163 06/12/18 05:48 PM
Z
zeng Offline
Z
Deposit formation,contents of Na,Ca,Mg etc, sludge,varnish,low TBN , high TAN,residual [email protected]*C, fuel dilution % etc are merely/strictly noises.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4789145 06/17/18 11:42 AM
1
1JZ_E46 Offline
1
Respectfully disagree. What a dense statement.
