Discount Tire Direct flash sale
by c502cid - 09/23/19 01:49 AM
Discount Tire Direct Instant $100 Savings One Day ONLY
by 71Chevyguy - 09/23/19 01:48 AM
Hankook Fall Rebate
by FordBroncoVWJeta - 09/22/19 11:23 PM
Axle and exhaust fixes this weekend
by Colt45ws - 09/22/19 11:07 PM
Maxlife v dex/merc
by HyundaiAbuser - 09/22/19 09:24 PM
15,119 Mile Supertech UOA
by Stumpy - 09/22/19 08:54 PM
Rust-Oleum Factor 4
by CatCam2 - 09/22/19 08:20 PM
Local Walmart Magnatec Closeout- Maybe Others?
by SSerian - 09/22/19 07:32 PM
Anti theft measures for new truck
by Oldtom - 09/22/19 07:28 PM
What would you do?
by Rexinaus - 09/22/19 06:26 PM
What size wire for 5 HP motor?
by dlundblad - 09/22/19 06:12 PM
Studless V/S studded winter tires
by cecil56 - 09/22/19 06:10 PM
200K more to Go!
by Gebo - 09/22/19 06:07 PM
Toyota license plate bolts/screws
by edwardh1 - 09/22/19 05:38 PM
How Do You Clean Your Grill ?
by Warstud - 09/22/19 04:05 PM
Curious question?
by Bill_W - 09/22/19 03:06 PM
Haldex, Automatic on demand clutch fluid?
by sloinker - 09/22/19 03:02 PM
dburch, Hueiyeh, Texguy, jm1, Dunkaroo
69364 Registered Users
14 registered members (HappyLittlePony, Lowflyer, billt460, Debe, GMguy84, mk378, 1 invisible), 609 guests, and 23 spiders.
Topics294,932
Posts5,069,497
Members69,364
Most Online3,532
Jul 30th, 2019
How big, oil leak without dripping onto the ground #4783409 06/10/18 09:24 PM
W
WobblyElvis Offline OP
W
I have an 06 GM ecotec engine that was leaking oil from the valve cover on the forward side of the engine. The engine became covered in a dirty oily mess but it never dripped onto the ground so I didn't repair it for years. Finally sealed in up and the oil consumption dropped by about .2QT a month or .2QTs per 1,400 miles. I find it hard to believe all this oil was just evaporating. Is this possible?
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783414 06/10/18 09:31 PM
Shannow Offline
For leaks like that, look along the roads and highways, for that oily spot just after a bump in the road.
Those incipient drops get shaken off
e.g.
So quite probably the drops are getting shaken off at places like that.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783429 06/10/18 09:42 PM
W
W
In this case the oil never made it to the oil pan. I know the engine is hot and there is a warm breeze from the radiator but seems like a lot of oil to evaporate.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783779 06/11/18 11:05 AM
Hootbro Offline
Engine bays still have a lot of turbulent air in them at highway speeds. Any oil accumulation of any significance gets removed by such forces. Not a Scooby Doo mystery.
2020 Jeep Gladiator Rubicon 3.6L (Factory Fill 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
Re: How big, oil leak without dripping onto the ground [Re: Hootbro] #4783812 06/11/18 11:35 AM
4WD Offline
Saw a video where a guy removed the hood seal closest to windshield … claimed it cooled down his engine…
Always figured what you just wrote … and even at idle hot air is pushed out the bottom …
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783894 06/11/18 12:35 PM
crazy_raccoon Offline
A little different but with the Toyota 2AZ-FE motors (practically all Toyota 4 cyl vehicles from like '00 to '10) had issues with the piston rings and clogged piston oil return holes that made the engines burn oil. The problem was there were no leaks and the oil ended up burning away in the combustion chamber. People were burning upwards to a qt. of oil every 600 miles or even less miles than that.
'07 Scion tc
- 103K miles
- Valvoline FS w/ML 0W-20 D1G2
- FRAM Ultra
'07 Honda Accord coupe 4cyl
- 138K miles
- Supertech FS 5W-20 D1G2
- FRAM TG
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783901 06/11/18 12:41 PM
W
W
So it is possible for .2 qts/month of motor oil to evaporate from a warm engine? This appears to be what was happening. Anyone know the evaporation rate of motor oil?
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784650 06/12/18 08:22 AM
O
OilUzer Offline
O
I had a car that leaked very little oil but never on the ground that I could see. Sometimes I found dead bees or other gunk kind of soaked in oil around the gasket ...
That oil did not "evaporate".
sand, dirt, etc. can also absorb some oil from underneath the engine not visible to you and fall off ...
Also some oil sludge/gunk maybe back in areas not visible ...
You are only focusing on evaporation!
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784677 06/12/18 08:54 AM
W
W
Oil must evaporate to some extent. If I was to oil a rusty piece of sheet metal that sat outside it wouldn't be wet/oily forever.
There is another explanation for my decreased oil consumption. When I repaired the valve cover gasket I also switched oil brands and consumption has been down since that event. I've used many different brands/types of oil but they all burned or disappeared at the same rate. I find it hard to believe that the oil type is responsible for the drop in oil consumption. This is why I'm asking about oil evaporating from the warm exterior of an engine.
Oil consumption has fallen from 1 qt/3,300 miles to a qt/4,500 miles. The engine has over 200,000 miles on it.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784689 06/12/18 09:10 AM
F
FordCapriDriver Offline
F
My Escort leaks some oil, perhaps every 2 or 3 days i find a drop or two of oil on the ground.
Often i can see a small drop of oil that hasn't fallen yet on the bottom of the oil pan.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Shell Rimula R4X 15W-40 HDEO
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784692 06/12/18 09:17 AM
PimTac Offline
Many of the newer vehicles have resin under shields installed so minor leaks would be caught by them instead of going directly to the ground. The heat from the engine plus air movement could help evaporate anything that is minor.
As your car has that many miles on it, a common place for oil leaks would be the rear main seal. Check that area for any leaks or seepage.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: How big, oil leak without dripping onto the ground [Re: PimTac] #4784831 06/12/18 12:11 PM
W
W
There is no pan or tray under the engine and no other leaks. Oil has never made it down o the top of the pan. My money is on evaporation taking the lighter portions of the oil away.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784844 06/12/18 12:24 PM
H
HammerHead0313 Offline
H
Oil selection is more important than most think, especially in older high mile engines. I had a 1999 Dodge Ram with the 5.9 and it consumed 1 Quart of oil every 500 miles using full synthetic oil; swithed to a conventional oil and it cut my oil consumption by 50% using conventional oil.
