I am a first time ester user.
This is a Suzuki 90Deg twin liquid cooled cycle engine 1037cc variety. Six hundred mile first service, replaced the factory oil (said to be conventional) with Yamalube blended synthetic 10w-40.
I did not like results. On this bike, the sudden appearance of audible idle hammer following the first oil change is a well discussed subject a lot of owners report. Not actually harmful. Just an annoying, unwanted, and not uncommon idle knock sound that comes and goes at idle.
I did not like it. I hated it immediately. That was yesterday.
Today I pulled the drain plug and drained out everything that would come out. Didn't change the horizontally mounted filter. What drained out was about 80% of the oil capacity.
Replaced it with Bel Rey Synthetic Ester Blend. 15w-50
Took a long ride and everything behaved beautifully. Engine like silk, shifted perfectly smooth. (wet clutch)
And no noticeable Idle Hammer.
Was it okay to end up with about an 80/20 mixture? The two are compatible?
I take it 2-3000 miles is well within reason for range on this oil in this application?
The oil weight will come down before cold weather returns here to SE WI
thanks,
thanks,
