Cleaning Painted Alloy Wheels
by Wrenchturner44 - 08/25/19 03:57 PM
1988 cadillac brougham oil disappearing
by momo - 08/25/19 01:41 PM
Amp draw
by mjk - 08/25/19 01:36 PM
SHELL cracker plant
by 53' Stude - 08/25/19 12:03 PM
Mirrored Window Film
by Warstud - 08/25/19 11:40 AM
I want a Challenger
by Jarlaxle - 08/25/19 11:33 AM
Why not?🤔
by Mad_Hatter - 08/25/19 11:10 AM
CanAm OEM oil alternatives
by Carbon12 - 08/25/19 10:46 AM
2019 Dodge Ram Classic 1500 Big Horn Brakes
by Honda2003 - 08/25/19 10:45 AM
Pontiac V8 oil observation
by CheezWhiz - 08/25/19 10:42 AM
Dillemma ...
by Baveux - 08/25/19 10:41 AM
Schaeffers vs Mobil one
by salesrep - 08/25/19 10:04 AM
Moly EP grease
by rideon - 08/25/19 09:59 AM
grease in a golf cart clutch
by jacobsond - 08/25/19 09:53 AM
Pennszoil
by JohnnyJohnson - 08/25/19 09:32 AM
Clunk from the front when I let out the clutch
by atikovi - 08/25/19 09:16 AM
M1 5w30 SN+ D1 / G2 Make Up ?
by ChrisD46 - 08/25/19 09:07 AM
2015 F150 owners manual rear diff fluid options
by Buzzinhalfdozen - 08/25/19 09:02 AM
Recommend a 7 passenger w/10,000 tow
by sasilverbullet - 08/25/19 08:54 AM
Lawn tractor problem
by supton - 08/25/19 07:57 AM
Faux, jk1401, EricTwoCamaros, Subie5w30, Iautox
69057 Registered Users
91 registered members (007, 08z06, aircooled, 2K2AcuraTL, 2010Civic, 12 invisible), 2,317 guests, and 25 spiders.
Topics293,783
Posts5,046,669
Members69,057
Most Online3,532
Jul 30th, 2019
2010 EDGE brakes squeal only in reverse #4784002 06/11/18 03:20 PM
53' Stude Online Content OP
OP Online Content
Friends 2010 Ford EDGE. 70k on it and he just did rear rotors and pads and now hears squealing passenger rear brakes. Only in reverse. Any ideas?
Thanks gentlemen
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784006 06/11/18 03:25 PM
The Critic Online Crying
Online Crying
What brand of parts did you use?
2011 Toyota Prius 1.8L - 195K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784008 06/11/18 03:27 PM
OP Online Content
HE used MC or Motorcraft rotors and pads sir smile
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784010 06/11/18 03:29 PM
bdcardinal Offline
Did he wash the rotors with soap and hot water before installing?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784016 06/11/18 03:36 PM
2
2009Edge Offline
2
My 09 Edge had the emergency brake in the small drum inside the rear rotors. could be the squeal origin.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784020 06/11/18 03:36 PM
OP Online Content
Im not sure but he did brake clean the rotors off he said
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784035 06/11/18 03:54 PM
SirTanon Offline
Sounds like he either didn't replace some or all of the hardware when he did the pads, or he forgot to clean and lube some of the pins... or maybe forgot to clean the hub surface.
2013 Nissan Altima SV - 2.5 liter/CVT - 118,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 67,000mi
2010 Ford Fusion - 274,500mi
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784314 06/11/18 08:43 PM
ddtmoto Offline
When they finish bedding in they may be fine. Patience....
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784334 06/11/18 09:04 PM
H
hallstevenson Offline
H
Have him quickly re-do the pads and hardware and properly apply grease to the hardware (both sides). Remove the hardware, apply grease to the caliper frame, re-install the hardware, apply grease, then the pads.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784390 06/11/18 09:59 PM
Online Crying
Probably a hardware issue. Have him make sure all of the rust was removed from the bracket before installing the new clips.
