Thread Repair Question
by The Critic - 08/19/19 02:48 AM
Genuine Mercedes-Benz 229.5 5W-40 Engine Oil
by The Critic - 08/19/19 02:25 AM
Is it safe to use 100% synthetic
by Espada - 08/19/19 02:16 AM
Cobb Air Filter Cleaning
by The Critic - 08/19/19 01:58 AM
PCV side of the engine is cleaner
by OilUzer - 08/19/19 01:50 AM
Which is Better: Old or New Castrol Edge 0W-40?
by nielkfj - 08/19/19 01:18 AM
Discount Tire Warranty
by Maddog1337 - 08/19/19 12:26 AM
Mobil One Super Synthetic Euro 5W-40
by hellokitty - 08/18/19 11:26 PM
Help Me Search
by Gebo - 08/18/19 09:29 PM
2018 Camry Transmission Drain & Refill Procedure
by painfx - 08/18/19 09:11 PM
.325 pitch vs .375 pitch saw chain
by The_Eric - 08/18/19 09:04 PM
House buying opinions on houses.
by ram_man - 08/18/19 08:50 PM
How to get nails out of my driveway?
by Chris142 - 08/18/19 08:37 PM
Used cars imported from Canada to USA on the rise?
by BobsArmory - 08/18/19 08:28 PM
2010 Accord P1009 Code
by Phishin - 08/18/19 08:15 PM
Espada, samhainlimon, CrazyElf, mattkocanda95, HardCoreHawkFan
68995 Registered Users
25 registered members (2015Corolla, 4WD, d00df00d, amh, carloz, Bailes1992, 5 invisible), 604 guests, and 24 spiders.
Topics293,497
Posts5,041,221
Members68,995
Most Online3,532
Jul 30th, 2019
2017 WRX STI: Motul X-clean EFE - 5,000 miles #4784224 06/11/18 07:16 PM
T
Tiir Offline OP
T
Motul X-clean 5w-30 EFE fill.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784236 06/11/18 07:28 PM
O
oil_film_movies Offline
O
Copper is probably from the oil cooler. Its been seen a lot on WRX engines. The other possible source is the crank bearings, yet it just seems unlikely here.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784565 06/12/18 06:58 AM
Snagglefoot Offline
For what itís worth that is a very low iron number, down at 1 ppm/ 1000 miles. Where the other checks with the same Motul oil?
If you want the job done right......do it yourself.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784694 06/12/18 09:18 AM
G
Gubkin Offline
G
"TBN is still good at 2.2. Try 7000 miles"
Crazy lab! )))))))
It's mean that TBN > TAN
necessary decrease interval to 4000 miles
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784713 06/12/18 09:32 AM
K
kschachn Offline
K
What?
Crazy lab! )))))))
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784735 06/12/18 10:00 AM
G
Gubkin Offline
G
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784746 06/12/18 10:07 AM
Z
zeng Offline
Z
Very good metal wear rates.
Cu and (part of) Al likely comes from cooler, not bearing.
This C3 oil of TBN 7.8 drops to 2.2 over 5100 miles, which I interprete as good TBN retention.
I won't look at TAN , if any, and agree with BStone OCI could be extended further to 7000 miles or probably beyond.
Edit:The test of the pudding is in the eating, which in this case refers to (the very good) Fe wear of 5 ppm over 5100 miles.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784786 06/12/18 11:10 AM
B
bluesubie Offline
B
I believe that Blackstone uses a different ASTM test than either of those (at least they used to).
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=221275
I doubt the OP will extend the interval very much. And probably not likely to go beyond 6k miles which is Subaru of America's recommendation unless Blackstone will cover the Powertrain Warranty. smile2
'04 Subaru Forester 2.5XT
Castrol Edge 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4784788 06/12/18 11:15 AM
1
1JZ_E46 Offline
1
Wear metals ppm is only a piece of the story. You will not see deposit formation in a UOA, which you get from low TBN or where TAN is higher than TBN.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4785143 06/12/18 06:29 PM
K
kschachn Offline
K
What is the TAN here?
1994 BMW 530i, 246K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: 1JZ_E46] #4785163 06/12/18 06:48 PM
Z
zeng Offline
Z
Deposit formation,contents of Na,Ca,Mg etc, sludge,varnish,low TBN , high TAN,residual [email protected]*C, fuel dilution % etc are merely/strictly noises.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4789145 06/17/18 12:42 PM
1
1JZ_E46 Offline
1
Respectfully disagree. What a dense statement.
