Alternative oil filters
by GeoffPD - 08/24/19 10:16 PM
PartSource Canada Delvac deal
by Bluestream - 08/24/19 09:57 PM
Chamberlain tractor pto clutch oil
by Jabbo - 08/24/19 09:37 PM
how to get out o2 sensor
by dogememe - 08/24/19 09:18 PM
Should I use a wash and wax for maintenance washes?
by littlehulkster - 08/24/19 08:53 PM
Michelin Rebate
by twouvakind - 08/24/19 08:47 PM
Meguiar's Ultimate Fast Finish.
by irv - 08/24/19 08:27 PM
Fram PH/TG/XG3593a cut open
by SlavaB - 08/24/19 08:12 PM
Supertech vs OEM
by Bettez88 - 08/24/19 08:05 PM
Exxon Mobile Synergy Supreme Friction Modifier
by IndyFan - 08/24/19 07:50 PM
Toyota oil cap funnel
by Patrick0525 - 08/24/19 07:07 PM
STUMPED (2002 BMW X5)
by Kira - 08/24/19 05:43 PM
Turtle Wax Zip wash/wax...garbage!
by gregk24 - 08/24/19 05:41 PM
Does Super Lube Oil make Good Electric Motor Oil
by vortex - 08/24/19 04:40 PM
26 degree temp swing in 24 hours
by gman2304 - 08/24/19 04:12 PM
FEDERATED PG4459F CUT OPEN
by 53' Stude - 08/24/19 03:58 PM
Reverse mortgage questions.
by callbay - 08/24/19 03:45 PM
Moly vs No Moly
by Navi - 08/24/19 03:08 PM
EricTwoCamaros, Subie5w30, Iautox, Mayadi, YachtRocket
69055 Registered Users
94 registered members (AdditiveOCD, 2003f7, 53' Stude, Alfred_B, 2010Civic, Ag76, 9 invisible), 1,617 guests, and 24 spiders.
Topics293,754
Posts5,046,143
Members69,055
Most Online3,532
Jul 30th, 2019
Bleeding air from cooling system - Zetec #4784065 06/11/18 04:32 PM
I
Ifixyawata Offline OP
I
Hi all:
I've read differing opinions but I know there are some very knowledgeable Zetec/Focus people on this board. I have had a seeping, developed to full blown leaking heater/coolant hose on my Focus and I just replaced it today. It's the one the runs from the thermostat housing to the front plastic'crossover' pipe, I didn't lose much coolant at all replacing it, I topped off the coolant tank and ran the car for about 5 minutes. The heat works and the hose is getting hot.
Do I need to burp air out of the cooling system on this car? I've read that because it's a pressurized tank, yadda yadda that it's sort of self-burping.
2004 Mercury Mountaineer 4.6 M1 High Mileage 10w-40 (Summer)
2001 Ford Focus 2.0 Zetec Pennzoil Euro L 5w-30
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784077 06/11/18 04:44 PM
SirTanon Offline
If the heat works and the hose is getting hot - and I'm assuming this also means your heater puts out HOT air, not just warm - then I'd say you're not in any immediate danger. If I were in your shoes, I'd take the car out, somewhere close to home, and put it through the paces for 5-10 minutes.. Try your best to keep it at a somewhat consistent RPM range between 2000 and 2500 RPM. This should force any remaining bubbles of air to a spot they can burp out naturally.
Make sure you keep a close eye on the temperature while you're doing this, just to be safe.
Where I live, there's a highway very close by, with an exit near me, and another about 3 miles down. IMHO, this would be the perfect place. Get it up to highway speed, hold it at RPM, get off after 3 miles, turn around and go back.
2013 Nissan Altima SV - 2.5 liter/CVT - 118,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 67,000mi
2010 Ford Fusion - 274,500mi
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784083 06/11/18 04:52 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I just keep topping off the coolant every morning until it can't take any more.
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784122 06/11/18 05:48 PM
K
KrisZ Online Content
Online Content
K
Never had to bleed it on my old ZX5 when I changed the thermostat housing. If the level in the pressurized tank goes low, just top it off when the system is cold.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784131 06/11/18 05:54 PM
slacktide_bitog Offline
The Focus Zetec is one of the easier cars to bleed the coolant on. Just fill it, leave the cap open, turn the heat to full blast, let it warm up, and wait for the bubbles to stop.
Of course, if you're still having trouble with it, the Lisle funnel is awesome smile
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784156 06/11/18 06:16 PM
E
eljefino Offline
E
Some cars that bleed hard, I remove the top radiator hose from the radiator and stretch it up as high as it'll go, and pour coolant in that to back-force it through the engine until it dribbles out the now-open radiator. This with the car on ramps so it's a higher spot.
Some cars with the thermostat up top make this hard, IDK how the zetec does it.
I think you should keep doing what you're doing. Grab the top hose and massage it to feel if you have any bubbles.
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784201 06/11/18 06:53 PM
T
Trav Offline
T
As Kestas said keep topping it off til it stabilizes, if the hose is getting hot you have circulation and it will expel the air after a few cool downs.
Hard to bleed engines are becoming more common in the US but in Europe its been a problem for years especially on some diesels.4
Vacuum filling is the only way to get system filled quickly and air free, I highly recommend a vacuum filler for anyone doing DIY cooling system service.
Right now ECS tuning has a great unit on sale for under $60, they have a sale on it a few times a year. It is a well made quality piece at a great price.
https://www.ecstuning.com/b-schwaben-parts/coolant-refill-air-purge-tool/003466sch01/
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784242 06/11/18 07:37 PM
SubieRubyRoo Offline
I 2nd Trav's note about vacuum units. My brother is a wrench also, and he says there are some Chevys and other vehicles that are darn near impossible to bleed without using a vacuum unit. If you can't use the Lisle funnel or have the bleeder line like the Ford/Mazda 2.5s, vacuum bleeder may be your best friend.
Re: Bleeding air from cooling system - Zetec [Re: Trav] #4784500 06/12/18 04:31 AM
demarpaint Offline
Thanks for posting! I grabbed one. Some cooling systems I've encountered can be a PITA to bleed.
God Bless Our Troops
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784515 06/12/18 05:41 AM
I
I
Thank you all for the replies. I turned on the bluetooth OBDII scanner and watched my coolant temp on my ride in to work, seemed to run about 210 - 220 the whole time except for the brief period of "robust accelleration" where it did hit 233, but it came right back down into the 215 range quickly.
When I got to work I opened the hood with it still running and checked and lo and behold I still had coolant. I verified by opening the cap as you can't really see through the old clear bottle very well but sure enough there's coolant in there. What's strange is there didn't seem to be any hiss or relief of pressure when I opened the overflow tank/bottle, and the coolant in there was really only warm to the touch. Yes, I touched it because curiosity. Is this normal?
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784588 06/12/18 07:24 AM
T
Trav Offline
T
Sounds like there may be air in there somewhere.
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784805 06/12/18 11:43 AM
I
I
I'm currently taking my lunch break in my car, have it running with the cap off, well see if this helps
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784810 06/12/18 11:51 AM
T
Trav Offline
T
Be careful not to overheat the thing, then you have a problem. Check fan operation, make sure it is coming on and going off when the temp drops.
Re: Bleeding air from cooling system - Zetec [Re: Trav] #4784817 06/12/18 11:57 AM
I
I
Been running at idle for about 15 minutes and just now at 200F
Re: Bleeding air from cooling system - Zetec [Re: Ifixyawata] #4784845 06/12/18 12:24 PM
K
Online Content
K
You may want to increase the revs a bit, to about 1500-2000 RPM. It will speed up the bleeding process. Monitor the temps during this time of course.
