How Often To Use CRC IVC ?
by ChrisD46 - 11/19/19 03:28 AM
SEARS: 4 Stroke/Lawnmower Maintenance Deals
by GumbyJarvis - 11/19/19 02:17 AM
Pepboys Coupon
by Xeno - 11/19/19 02:12 AM
Pennzoil “Designed for Your Drive”
by LubeFiner - 11/19/19 02:09 AM
Ebay $15 of $75 purchase
by GMguy84 - 11/19/19 12:06 AM
How thorough are coolant flushes at auto shops?
by Whammo - 11/18/19 10:58 PM
Fixed Orifice PCV design and issues.
by Talent_Keyhole - 11/18/19 10:44 PM
Redline Si-1 turning the light out
by lukejo - 11/18/19 10:16 PM
Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Joe_Cena, MickWK, DaveOilStack, spiffy63, WhiteMega1227
69911 Registered Users
40 registered members (Bailes1992, 53' Stude, 77GrandPrix, BBDartCA, Bookmaker, 6 invisible), 1,028 guests, and 18 spiders.
Topics297,619
Posts5,119,361
Members69,911
Most Online3,589
Nov 2nd, 2019
2010 EDGE brakes squeal only in reverse #4784002 06/11/18 02:20 PM
53' Stude Online Content OP
OP Online Content
Friends 2010 Ford EDGE. 70k on it and he just did rear rotors and pads and now hears squealing passenger rear brakes. Only in reverse. Any ideas?
Thanks gentlemen
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784006 06/11/18 02:25 PM
The Critic Offline
What brand of parts did you use?
2011 Toyota Prius 1.8L - 199K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 140K - Valvoline Premium Blue Restore 10W-30
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784008 06/11/18 02:27 PM
OP Online Content
HE used MC or Motorcraft rotors and pads sir smile
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784010 06/11/18 02:29 PM
bdcardinal Offline
Did he wash the rotors with soap and hot water before installing?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784016 06/11/18 02:36 PM
2
2009Edge Offline
2
My 09 Edge had the emergency brake in the small drum inside the rear rotors. could be the squeal origin.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784020 06/11/18 02:36 PM
OP Online Content
Im not sure but he did brake clean the rotors off he said
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784035 06/11/18 02:54 PM
SirTanon Offline
Sounds like he either didn't replace some or all of the hardware when he did the pads, or he forgot to clean and lube some of the pins... or maybe forgot to clean the hub surface.
2013 Nissan Altima SV - 2.5 liter/CVT - 123,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 69,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784314 06/11/18 07:43 PM
ddtmoto Offline
When they finish bedding in they may be fine. Patience....
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784334 06/11/18 08:04 PM
H
hallstevenson Offline
H
Have him quickly re-do the pads and hardware and properly apply grease to the hardware (both sides). Remove the hardware, apply grease to the caliper frame, re-install the hardware, apply grease, then the pads.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784390 06/11/18 08:59 PM
The Critic Offline
Probably a hardware issue. Have him make sure all of the rust was removed from the bracket before installing the new clips.
