2008 Yamaha F350 91 Hrs OCI
by nicklx. 06/24/19 08:39 PM
Guess your never too young to work on a chevy.
by rollinpete. 06/24/19 08:13 PM
Went to Jiffy Lube
by Stelth. 06/24/19 07:37 PM
safest way to remove bug residue
by NissanMaxima. 06/24/19 07:32 PM
22000 emails
by marine65. 06/24/19 06:31 PM
oil analysis to show fuel dilution
by jfairchild327. 06/24/19 06:00 PM
Mitsu 3000GT rear engine mount is tilted...
by tomcat27. 06/24/19 05:52 PM
Engine full of Fuel. What is best to do?
by LeoStrop. 06/24/19 05:50 PM
Seeking Advice Choosing Wheel Locks
by JerryBob. 06/24/19 05:19 PM
Non-stick pan
by Alfred_B. 06/24/19 05:04 PM
Had to ELIMINATE a raccoon
by Kjmack. 06/24/19 04:52 PM
Oil Consumption 6.0L AFM Unicorn?
by tahoe_hybrid. 06/24/19 04:27 PM
PP 5W-20, 3000mi, '14 Kia Soul
by tc1446. 06/24/19 03:07 PM
Cheap powerfull filter magnet
by loneryder. 06/24/19 01:50 PM
New road tire time
by UG_Passat. 06/24/19 01:46 PM
Royal Purple 75W90 vs. Store Brand Synthetic
by WondrousBread. 06/24/19 12:50 PM
Jeep Renegade MTF Alternatives?
by Sunnyinhollister. 06/24/19 12:28 PM
Havoline 0W20 VI higher than 5w30 and 10w30?
by Whammo. 06/24/19 12:10 PM
New toy...19 Jetta GLI Autobahn
by CincyDavid. 06/24/19 12:00 PM
ml98188, 84FSP, megavoyager, thaduke2003, Vitaliy
68474 Registered Users
132 registered members (2010Civic, 77GrandPrix, 97K15004WD, 53' Stude, aba4430, 13 invisible), 2,176 guests, and 30 spiders.
Topics290,916
Posts4,995,239
Members68,474
Most Online2,967
Mar 10th, 2019
2010 EDGE brakes squeal only in reverse #4784002
06/11/18 03:20 PM
06/11/18 03:20 PM
In the shop
53' Stude Online content OP
53' Stude  Online Content OP
In the shop
Friends 2010 Ford EDGE. 70k on it and he just did rear rotors and pads and now hears squealing passenger rear brakes. Only in reverse. Any ideas?
Thanks gentlemen
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784006
06/11/18 03:25 PM
06/11/18 03:25 PM
CA
The Critic Online crying
The Critic  Online Crying
CA
What brand of parts did you use?
2011 Toyota Prius 1.8L - 190K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784008
06/11/18 03:27 PM
06/11/18 03:27 PM
In the shop
In the shop
HE used MC or Motorcraft rotors and pads sir smile
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784010
06/11/18 03:29 PM
06/11/18 03:29 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Did he wash the rotors with soap and hot water before installing?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784016
06/11/18 03:36 PM
06/11/18 03:36 PM
Texas
2009Edge Offline
2009Edge  Offline
Texas
My 09 Edge had the emergency brake in the small drum inside the rear rotors. could be the squeal origin.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784020
06/11/18 03:36 PM
06/11/18 03:36 PM
In the shop
In the shop
Im not sure but he did brake clean the rotors off he said
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784035
06/11/18 03:54 PM
06/11/18 03:54 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Sounds like he either didn't replace some or all of the hardware when he did the pads, or he forgot to clean and lube some of the pins... or maybe forgot to clean the hub surface.
2013 Nissan Altima SV - 2.5 liter/CVT - 114,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 65,000mi
2010 Ford Fusion - 274,000mi
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784314
06/11/18 08:43 PM
06/11/18 08:43 PM
Utah
ddtmoto Offline
ddtmoto  Offline
Utah
When they finish bedding in they may be fine. Patience....
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784334
06/11/18 09:04 PM
06/11/18 09:04 PM
Ohio
hallstevenson Offline
Ohio
Have him quickly re-do the pads and hardware and properly apply grease to the hardware (both sides). Remove the hardware, apply grease to the caliper frame, re-install the hardware, apply grease, then the pads.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784390
06/11/18 09:59 PM
06/11/18 09:59 PM
CA
CA
Probably a hardware issue. Have him make sure all of the rust was removed from the bracket before installing the new clips.
