MacBook Pro Issues?
by miden851 - 10/14/19 05:28 PM
Any aquarists in the house?
by Mad_Hatter - 10/14/19 04:39 PM
Motorcraft Spark Plugs on Ebay?
by panthermike - 10/14/19 04:25 PM
Change Fram Ultra with 720 hours on it?
by CharlieBauer - 10/14/19 04:02 PM
Powerstop Brake kits
by RhondaHonda - 10/14/19 03:00 PM
Oil recommendations
by Speak2Mountain - 10/14/19 02:28 PM
Maxlife ATF
by charmer37 - 10/14/19 02:18 PM
Anyone want a NAPA GOLD 1334 and FRAM ULTRA 3593A
by 53' Stude - 10/14/19 01:59 PM
Sams Choice Cuban Style Mustard
by skyactiv - 10/14/19 01:55 PM
Front suspension still making noise
by A_A_G - 10/14/19 01:20 PM
What is this? It says SmartGear
by JLawrence08648 - 10/14/19 12:20 PM
2004 Toyota Sienna
by Char Baby - 10/14/19 11:48 AM
Installing your own winter tires
by Snagglefoot - 10/14/19 10:43 AM
2018 Subaru Forester Premium 11mo Review
by badtlc - 10/14/19 10:40 AM
Good price on Mobil 1 Delvac 75w-90?
by kehyler - 10/14/19 09:09 AM
Ford IDI diesel starters
by bullwinkle - 10/14/19 09:07 AM
Portable Induction Bolt Heater
by billt460 - 10/14/19 06:51 AM
Coil springs, is there a top and bottom?
by LeakySeals - 10/14/19 06:20 AM
HotelPrisoner, Germanium, ffr1222k, Laurie, messerschmitt
69554 Registered Users
106 registered members (08z06, 4WD, 2015_PSD, 2002 Maxima SE, 13 invisible), 2,154 guests, and 50 spiders.
Topics295,964
Posts5,088,263
Members69,554
Most Online3,532
Jul 30th, 2019
2010 EDGE brakes squeal only in reverse #4784002 06/11/18 03:20 PM
53' Stude Offline OP
Friends 2010 Ford EDGE. 70k on it and he just did rear rotors and pads and now hears squealing passenger rear brakes. Only in reverse. Any ideas?
Thanks gentlemen
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784006 06/11/18 03:25 PM
The Critic Online Crying
Online Crying
What brand of parts did you use?
2011 Toyota Prius 1.8L - 197K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 139K - Valvoline Premium Blue Restore 10W-30
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784008 06/11/18 03:27 PM
HE used MC or Motorcraft rotors and pads sir smile
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784010 06/11/18 03:29 PM
bdcardinal Online Content
Online Content
Did he wash the rotors with soap and hot water before installing?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784016 06/11/18 03:36 PM
2
2009Edge Offline
2
My 09 Edge had the emergency brake in the small drum inside the rear rotors. could be the squeal origin.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784020 06/11/18 03:36 PM
Im not sure but he did brake clean the rotors off he said
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784035 06/11/18 03:54 PM
SirTanon Offline
Sounds like he either didn't replace some or all of the hardware when he did the pads, or he forgot to clean and lube some of the pins... or maybe forgot to clean the hub surface.
2013 Nissan Altima SV - 2.5 liter/CVT - 121,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,500mi
2010 Ford Fusion - 274k mi - SOLD
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784314 06/11/18 08:43 PM
ddtmoto Offline
When they finish bedding in they may be fine. Patience....
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784334 06/11/18 09:04 PM
H
hallstevenson Offline
H
Have him quickly re-do the pads and hardware and properly apply grease to the hardware (both sides). Remove the hardware, apply grease to the caliper frame, re-install the hardware, apply grease, then the pads.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784390 06/11/18 09:59 PM
Online Crying
Probably a hardware issue. Have him make sure all of the rust was removed from the bracket before installing the new clips.
