Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
99 registered members (badtlc, Best F100, Black_Thunder, Astro14, 53' Stude, 14 invisible), 2,216 guests, and 55 spiders.
Topics296,781
Posts4,958,806
Members66,969
Most Online2,577
Jan 14th, 2019
2010 EDGE brakes squeal only in reverse #4784002
06/11/18 02:20 PM
06/11/18 02:20 PM
In the shop
53' Stude Online content OP
53' Stude  Online Content OP
In the shop
Friends 2010 Ford EDGE. 70k on it and he just did rear rotors and pads and now hears squealing passenger rear brakes. Only in reverse. Any ideas?
Thanks gentlemen
09' Camry LE
ST 5w30 and TG 4386(filter on for second 5k run)
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784006
06/11/18 02:25 PM
06/11/18 02:25 PM
CA
The Critic Offline
The Critic  Offline
CA
What brand of parts did you use?
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784008
06/11/18 02:27 PM
06/11/18 02:27 PM
In the shop
In the shop
HE used MC or Motorcraft rotors and pads sir smile
09' Camry LE
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784010
06/11/18 02:29 PM
06/11/18 02:29 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Did he wash the rotors with soap and hot water before installing?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784016
06/11/18 02:36 PM
06/11/18 02:36 PM
Texas
2009Edge Offline
2009Edge  Offline
Texas
My 09 Edge had the emergency brake in the small drum inside the rear rotors. could be the squeal origin.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784020
06/11/18 02:36 PM
06/11/18 02:36 PM
In the shop
In the shop
Im not sure but he did brake clean the rotors off he said
09' Camry LE
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784035
06/11/18 02:54 PM
06/11/18 02:54 PM
Phoenix, Arizona - USA
SirTanon Online content
SirTanon  Online Content
Sounds like he either didn't replace some or all of the hardware when he did the pads, or he forgot to clean and lube some of the pins... or maybe forgot to clean the hub surface.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 268,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 61,000mi
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784314
06/11/18 07:43 PM
06/11/18 07:43 PM
Utah
ddtmoto Offline
ddtmoto  Offline
Utah
When they finish bedding in they may be fine. Patience....
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784334
06/11/18 08:04 PM
06/11/18 08:04 PM
Ohio
hallstevenson Online content
hallstevenson  Online Content
Ohio
Have him quickly re-do the pads and hardware and properly apply grease to the hardware (both sides). Remove the hardware, apply grease to the caliper frame, re-install the hardware, apply grease, then the pads.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784390
06/11/18 08:59 PM
06/11/18 08:59 PM
CA
The Critic Offline
The Critic  Offline
CA
Probably a hardware issue. Have him make sure all of the rust was removed from the bracket before installing the new clips.
